Changing headlight bulbs on 95 Civic
I have a 95 Civic EX. I am trying to change the headlight bulbs but having difficulty doing it. I tried looking something up online without much help. Please feed some info
thanks
thanks
Since mine burn out every five years or so, going from memory:
unplug the connector
pull back the rubber boot
unclip the spring hold down
pull out the bulb
don't touch the glass of the new bulb
insert and reverse
pull out the bulb
insert and reverse
Also, for the left headlight bulb it is helpful if you move the power steering reservoir. Just slide it off the railing and push it back a little. Just remember to put it back on otherwise your belts will hit it.
