oxygen sensor removal
Old Dec 23, 2006 | 07:16 PM
little_chicken's Avatar
little_chicken
Little chicken~:>
Default oxygen sensor removal
i was trying to change my oxygen sensor and the old one stripped while taking it off, and yes i did get an oxygen sensor socket thing, any suggestions on how to get it off?
Old Dec 23, 2006 | 07:35 PM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
take the cat off...im assuming the o2 sensor your talking about is that one...take the cat to a shop that has air tools and see if they cant get it out....alot of times a air tool can spin fast enough to get a bolt/nut loose even if its stripped...only other thing i can think of is vise grips and patience....use alot of wd40...spray the o2 sensor prior to trying to remove it like 4 times every 5 mins with wd40 that should help alot
Old Dec 23, 2006 | 07:52 PM
little_chicken
Little chicken~:>
its the one on the header (and i think that is the only one in a del sol). and i have a compressor and an impact, didnt come out!! wd40, used alot and let it soke for a while, so now i have a half rounded off oxygen sensor on my header, and i couldnt get ahold of it good enough with vise grips
Old Dec 23, 2006 | 08:02 PM
t3t4delsol's Avatar
t3t4delsol
get a torch and heat it up, vice grips are gonna be your best bet
Old Dec 23, 2006 | 08:06 PM
ihartmacz's Avatar
ihartmacz
I tried to get my O2 off in my 1995 Civic I had, and I couldn't do it myself.
I used tons of PB Buster (penetrating oil) from the makers of SeaFoam, and still... No luck.
I took it in and they said they couldn't get it out, so they replaced my exhaust manifold and the O2 sensor.
Although I am skeptical, I'm not surprised.
Old Dec 23, 2006 | 08:32 PM
little_chicken
Little chicken~:>
if i gotta torch and heated it up wouldnt it damage it and cause my car to run worse, thats if i couldnt get it out
Old Dec 23, 2006 | 08:56 PM
t3t4delsol's Avatar
t3t4delsol
no, just dont burn the wires up, try this first, start the car up and let it run for a little till it warms up then try to take it off while its warm, (exhaust metals will try to bond together after a while do too all the heat) what the torch will do is break through the rust, and the bond
Old Dec 23, 2006 | 09:43 PM
little_chicken
Little chicken~:>
ugh, just put a torch to it, no luck.....stripped worse!!!
anyone have a header for sale?
Old Dec 24, 2006 | 05:09 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I actually have a D-series OBD-1 exhaust manifold that came off of my civic. Want it?
Old Dec 24, 2006 | 05:18 PM
nemesis25's Avatar
nemesis25
Use a bolt out kit from Sears. Costs about $60.
