95Civic overheating
My 95 civic DX was overheating a month ago. The temp was all the way to the red. After I researched, i realized the radiator fan was not running. So, I checked the fan, the t-stat, the cooland switch sensor, etc. After I changed the t-stat and coolant switch sensor, the fan works.
Last Friday, the car overheated again! The temp was all the way up at the red zone. The radiator fan is not running again! So, I checked the fan and the t-stat again. Both of them are still good. Is it possible that the coolant switch sensor is bad again??? How do I check the sensor to see if it is bad? Could it be headgasket leak?? Could it be water pump not working? How do I check??
I am going to throw this out there too. When I refill the coolant, i noticed that the coolant is muddy with some white residue. The white residue looks like the oil on your overnight leftover meal. So, I drained the coolant and refilled it.
I still can't figure out the problem. The fan is still not running. The car runs like crap. It is shaking when on idle. HELP!!!!!
Is there any coolant in the oil? Remove the oil cap and look under it, is it white?
Any excessive presure building up in the coolant system from gases entering it?
Where is the coolant going? Is it overflowing from the expansion tank or anywhere else? If not, you may be burning it. How's the exhaust smell/look?
The water pump may be bad, if you see coolant leaking out the weep hole of the pump, then it's bad.
You could have a bad t-stat (even though it's new) or rad cap. It could just be air trapped in there, did you bleed the system?
You may have to have compression test and/or leak down test done to find out if the head gasket is bad.
How long does it take to start over heating? My aux fan rarely runs-especially this time of year.
Is there any coolant in the oil? Remove the oil cap and look under it, is it white? I removed the oil cap, didn;t see white in the engine.
Where is the coolant going? Is it overflowing from the expansion tank or anywhere else? If not, you may be burning it. How's the exhaust smell/look? The coolant was boiling and flowing out from the expansion tank. I am not sure if the exhaust smells abnormal. But, there was white smoke coming out of the exhaust.
The water pump may be bad, if you see coolant leaking out the weep hole of the pump, then it's bad.Didn't see coolant leaking
You could have a bad t-stat (even though it's new) or rad cap. It could just be air trapped in there, did you bleed the system?I am quite sure the t-stat is good since I tested it by putting it in hot water. How do I bleed the coolant system? When I drained and refilled the coolant, I turned on the car, kept the rad cap off, and let the car idle for a good 30min. The coolant was boiling when i put the cap back on.
Any idea what could be wrong??
There's the bleed screw on the left front of the motor (just loosen it carefully if it has never been or it could snap off).
White smoke isn't really a good indicator if it's cold out, but if it's heavy white smoke then MAYBE the head gasket.
In these short trips, is it still using (loosing) coolant?
Without the the compression and/or leakdown and/or coolant sniffer test, it's hard to tell, especially with the short trips.
There's gotta be a way to test the fan for proper operation, I just know how. I'll see if it's in the Haynes manual.
How old is your radiator cap?
I still can't figure how come the fan is not turning on. If it was the head gasket, would it affect the cooling fan??
The radiotor cap is as old as the car.
Dude... You have a blown head gasket!!!!!!!! The white smoke means that water is getting in to your combustion chamber.
When mine was blown, my fan didn't turn on either. I don't know why, but it didn't.
