Engine Clicking???
Old Dec 14, 2006 | 05:35 PM
civicdx97's Avatar
civicdx97
Default Engine Clicking???
this clicking occurs whether the car is moving or not. also, its hard to tell from the video but the motor vibrates with each click. see video. if anyone has any ideas why this clicking occurs please reply.
http://www.youtube.com/watch?v=35w4jZAcaFM
thanks all
Old Dec 15, 2006 | 08:06 AM
99siDUDE's Avatar
99siDUDE
I would first start by hoping for the best and check if its misfiring. That vid looks simmilar to what happened to my motor when the spark plug gromets leaked oil, fouling up the plug wires. Cheap fix! Good luck!
Old Dec 15, 2006 | 08:40 AM
Running925's Avatar
Running925
Your Powder Coater
ok first off the thing needs a valve adjustment hella bad!
next.. the nosie that starts happening around 10sec into the video sounds like a rod flapping around! Unless that was u making the noise with something else.. but it only stays around for a few sec & then does it again twords the end of the clip.
Old Dec 15, 2006 | 09:05 AM
99siDUDE's Avatar
99siDUDE
Im thinking that if it were some internal failure, the sound would be continuous, rather than intermitent every few seconds.
Old Dec 15, 2006 | 10:33 AM
Running925's Avatar
Running925
Your Powder Coater
depends on whats wrong. It could be a bad section of a bearing that rotates and makes noise only when it's on a verticle portion, nobody will know till he rips it apart!
Old Dec 15, 2006 | 12:09 PM
m735is's Avatar
m735is
Sounds to me like the A/C compresor kicks on with the fan when it makes the noise. Is it on?
Old Dec 15, 2006 | 03:47 PM
VPUPPY's Avatar
VPUPPY
I have seen a few Civics do this. The magnetic clutch on the compressor may be going bad.
Old Dec 15, 2006 | 04:05 PM
sleezye's Avatar
sleezye
oh all that noise isnt normal
Old Dec 15, 2006 | 04:23 PM
civicdx97's Avatar
civicdx97
some people told me its most likely the a/c compressor since the clicking/vibrating stops if i turn off the a/c. I appreciate all the feedback on this. you guys are very helpful. I'll keep you posted if thats really the case.
thanks all
Jay
Old Dec 15, 2006 | 04:43 PM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
+1
sounds REALLY nasty to me....i wouldnt be driving...hope your not
but typically if it is a rod/bearing it would be constant as it worsens..so it could be a rod/bearing just hasnt gotten bad enough to be constant....ive experienced this on a 00 integra gsr...very sad
