View Full Version : '92+ Civic/EL & Del Sol
  1. 92 civic hatch with type r
  2. Tony's 2006 Build
  3. So I'm chipping my ECU and my 373 chip is too big.
  4. how to install side mirror signal lights
  5. how do wastegates work
  6. Head Gasket is going in 93 Civic EX Coupe...
  7. Info on eg JDM cluster?
  8. help with eg cluster
  9. Cat back system & SMOG Test
  10. 92 honda civic vx driveability need help
  11. building a turbo
  12. street/strip tires for civic bf goodrich
  13. high fuel pressure
  14. engine milage
  15. turbo killed my engine?
  16. Ebay ground wires any good?
  17. Steering wheel ring for Typr-R 98 Civic?
  18. How do I adjust civic headlights?
  19. guage cluster lights
  20. im confused on a h22 swap
  21. civic suspension help.
  22. Civic automatic shift knob removal?
  23. where do i tap in
  24. Buddy Club V-con vtec controller
  25. what size valve stems?
  26. After head gasket head cleaning d16z6
  27. What is this that came with my Moates.net kit?
  28. After head gasket head cleaning
  29. EBAY chips
  30. HELP How to rebuild a trans
  31. turbo for a 95 civic ex
  32. where to get b18b?
  33. Help About Performance Chip
  34. Rear sway bar vs. Exhaust (92 EG6)
  35. turbo masters need your help
  36. overheating please help
  37. Buying 1994 Civic DX - maybe
  38. Built GSR in a hatch, or Boosted D16z6?
  39. 2000 Civic power door lock control unit - where is it?
  40. Debadging a car
  41. help
  42. Post pics of your EK hatch.
  43. 97 Del Sol V Tec Air Conditioner Help
  44. Help!!!
  45. Exhaust for '05 Civic
  46. High flow Cat or Test Pipe?
  47. what rims are these
  48. wierd civic problem need help
  49. Overheating D16Z6
  50. neewd answer quick..Timing belt?
  51. Steering Wheel Noise, Click every 5 Sec.
  52. I need help
  53. how much for exhaust installation?
  54. Honda civic engine Swap
  55. For my Reference
  56. engine swap ideas?
  57. In-Dash Installation
  58. 93 civic dx with b18b1 has trans prob
  59. Procharger Superchargers
  60. Brake Swap Issue's
  61. Please help me I am Newbie
  62. civic port and polish
  63. Finally Boosted
  64. sleeper look?
  65. head unit/keyless entry/interior light electrical problem
  66. best looking headlight bulbs with best output???
  67. Newb: Hard to add A/C and PS?
  68. d16z6 to d15b vtec extra sensor??? Pics
  69. Question about replacing an exhaust
  70. Newbie Needs Help with 02 sensor
  71. 00 civic, wiring diag ... please
  72. Catalytic converter Queens NYC
  73. 94 Del Sol Si w/ 96 Integra tail light conversion????
  74. heads off chipped cylinder wall
  75. Coilovers
  76. Greddy Sp2 louder than Apexi WS2?
  77. FITV backed out again, can I locktite it or something?
  78. thx
  79. How did i bend this?!!
  80. ?Where to get new parts online?
  81. 1992 honda civic hatchback engine swap
  82. Time at the track
  83. S0 i finally ran at the track and.........
  84. no tach to tach
  85. what the crap
  86. omni quick clutch
  87. Oil pan the same? d16z6 / d15b vtec
  88. ok,low idle stock d16y8,now!
  89. Couple questions...
  90. Low Idle....d16y8
  91. ZEX™ Dry Nitrous Kit Question
  92. How do u guys like my 99 honda civic hx
  93. Best place to run hoses to/tap intake manifold.
  94. Valve Spring Height intake vs. exhaust
  95. best CF hood and CF trunk
  96. header question
  97. New user/Need Help
  98. 1999 civic si
  99. Making D17A2 super engine!!!
  100. valves
  101. Del Sol Roadtrip
  102. A pic of the HX
  103. Manuals....
  104. my EG6
  105. D16 Crank
  106. bleeding clutch in civic
  107. Steering Wheel
  108. car drinking water
  109. Rota Slipstreams
  110. how many psi?
  111. My car won't start...HELP!!!
  112. 17's are chippen
  113. cam gears
  114. help what to do cylinder misfire 1, 2, 3, & 4
  115. apexi n1? question
  116. gas gauge wont go down.. help!
  117. trouble starting up
  118. O2 sensor P0141
  119. Exhausts interchangable throughout different trims?
  120. How to reset maintenance require light on 01-03 civic?
  121. Vtec
  122. 37820-p08-911 469-200180 (jdm Ecu) Mt?
  123. problem with battery
  124. temperature sensor
  125. fuel filter
  126. removing door panel
  127. drums
  128. 75 shot on b16with 72k?
  129. 2004 Civic EX auto transmission
  130. headlight bulbs
  131. 5th gen civic headlight buzzer
  132. clock fuse
  133. 93 del sol s or si???
  134. Civic LX 1995 Brake Dilemma
  135. shootin..... .NOS...advice
  136. Need turbo Opinions to make final decision
  137. YAY for more efficient set up!! PART2!!!
  138. Do i cut.........
  139. Suspension dilemma
  140. Changing front Struts with coilovers
  141. 1994 Civic DX Rear Brake Swap
  142. question 4 da single cams?!?!
  143. Blinker Speeds
  144. Seatbelt Chime on '06 Civic
  145. Windshield Motor Wiper is damaged
  146. turbo kits
  147. 02 civic intake
  148. Exhaust bolts
  149. 1990 civic si ecu
  150. recommened mechanic in ca
  151. fogged up
  152. bump on the floor of my car
  153. CEL distributor problem
  154. silent exaust
  155. Blinker Issue
  156. head light bulbs? which kind?
  157. Choosing a transmission?
  158. Help with D16z6 AUTO into D15by Manual
  159. 92 civic si motor picture needed!!!
  160. Short Ram VS OEM Intake
  161. disk conversion which camber kit?
  162. need to find other parts
  163. new civic owner
  164. Key Replacment
  165. camber / alignment ?s
  166. wheel bearing... maybe
  167. buying zc
  168. buying a d16
  169. G2 Euro Double Projector Headlights
  170. civic 1985/86 head exchange leaded vs unleaded petrol
  171. Need help
  172. Replacing outside trim...
  173. 93 Eg
  174. What's the db's on a oem civic horn
  175. i need your input!!!
  176. map sensor for turbo diode
  177. buying zc
  178. spoon civic-how much power?
  179. Clutch Instrall Problem
  180. zc
  181. coilovers
  182. B16A obd1 into a 99 civic dx help
  183. Ignition Troubles?
  184. Installing rear trailing arm bushings?
  185. camber kit
  186. B-series swap or turbo?
  187. H&R civic/integra dilema
  188. turbo gurus ive got a head scratcher
  189. Its Me Again
  190. SOHC Power, need help
  191. To Members In Arizona
  192. SOHC Engine
  193. SiR II Swap Questions
  194. Totalled the civic.
  195. Need a shop in SOCAL that can fix this
  196. Help Plz
  197. can somebody help
  198. the juice
  199. Got an Auto? Want a manual?
  200. How To Remove The Stock Plastic Side Skirting
  201. almost boosted
  202. 2004 Civic -- Fuel Gauge
  203. power windows & locks?
  204. 2004 Civic Engine Failure
  205. 2001-05 Civic/CR-V Repair Manual: Haynes vs. Chilton
  206. Exhaust Header: 1 Piece vs 2 Piece
  207. 92civic grey trim interior question
  208. Instrument Cluster Vs. Tachometer
  209. type zero side skirts
  210. question on injectors
  211. ek obd2b harness
  212. 90 b18a1 into 95 civic coupe
  213. zc swap
  214. Check Engine Light
  215. Ractive Gauge Cluster Power Supply
  216. EXEL Paris chrome wheels
  217. What would u say i might run ?!?!?!?!
  218. My money pit has a new problem.
  219. Another d15b vtec question (timing belt)
  220. clutch on 94 civic help!!!!
  221. 1996-1998 Honda Service Publication
  222. Spoon shift knob?
  223. oil change hi miles 96 civic
  224. TURBO EXPERTS I need info
  225. I'm looking for a 93-95 Del Sol without an engine.
  226. turbo kits What is needed
  227. Temp gauage in cluster
  228. what parts to cover when degreasing engine 96 civic lx
  229. Loose parking brake on 96 civic lx
  230. turn signals wont turn off after turning on 96 civic lx
  231. 95 teg engine oem mounts work on eg
  232. broken driver side power door lock on 96 civic
  233. 94 civic coupe jdm b16a2 for sale
  234. coilovers
  235. need help removeing o2 sensor
  236. wheel hop/vibration
  237. Seal Problem
  238. Left Door Inop
  239. four cam four cyl?
  240. When replacing wheels...
  241. Is this turbo good???
  242. Supercharger Or Turbo??? For D16y8
  243. Cleaned out cat or high flow cat?
  244. future plans?
  245. supercharger for d16y8
  246. Si Hatch 02-03 or 04-05
  247. redline on del sol
  248. Axle Leak
  249. so many choices need some advice?
  250. Had some fun yesterday
go
