Car not Starting, Need Expert Help!!!
Old Apr 3, 2006 | 06:26 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
Default Car not Starting, Need Expert Help!!!
This might get moved to engine tech but here it goes.
I have a weird one for you guys my car from time to time will not start, when I turn the key all the way I will sometimes hear the starter click but not turn and sometimes I hear a sound coming from my ecu as if it was a Pentium 1 trying to process(random static type sound). I tried replacing the starter, battery and terminal wires and nada it still persists.
Anyone else have this problem? BTW this is on a 96 Civic Ex Sedan Auto.
I tried everything and nothing. Tried Searching online and found this and it is exactly the same as my car, bad ecu?
Please help.
Old Apr 3, 2006 | 07:18 PM
Wharbone's Avatar
Wharbone
Is it throwing a CEL. When my ECU went bad, the engine check light came on.
Will it crank at all?
Old Apr 4, 2006 | 12:31 AM
thecarguy's Avatar
thecarguy
is there a certain time when it does this? cold starts? hot start? Does it run good when it does start? Check engine lights? Need more info. Could be a number of things.
