Help Fixing Rust On Back Corner Panels
Old Apr 5, 2006 | 02:18 PM
JDM92CIVIC's Avatar
JDM92CIVIC
Default Help Fixing Rust On Back Corner Panels
i never used bondo or any thing, here are some pics, it would help alot it someone would look at them and tell me the easy way to fix that the best i could.Because im getting it ready to be painted.thanx
Old Apr 5, 2006 | 02:24 PM
sherwood's Avatar
sherwood
I missed Sean
strip it, cut out the rust, bondo, sand.
Old Apr 7, 2006 | 09:57 AM
Mbe25's Avatar
Mbe25
well im sorry but i just registered to this forum just to say that is the worst body advice i have ever heard. you shouldnt hand out advice when you dont know what you are talking about.
i have a little bit of a clue however.
1. sand paint off surrounding area
2.cut out the rust if its through the metal or if its surface rust, grind it off.
3. patch the metal with MORE metal not bondo if it is through. then skim coat it with some high quality bondo... if it is not through, skim coat the area with bondo.
4. then sand it, prime it etc..
it is a waste of your time in the long run when you just slab bondo over rust. it will come back to haunt you if you dont do it right.
Old Apr 7, 2006 | 10:02 AM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
Umn... you just said the exact same thing as sherwood - sorry you wasted your time registering just to :repost: what he said.
Old Apr 7, 2006 | 10:03 AM
Mbe25's Avatar
Mbe25
pretty sure he just said...put in the bondo. from the pics, it doesnt look like you can just slap mud in there.
Old Apr 7, 2006 | 10:35 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
It says on his post; cut out the rust doesnt he?
Old Apr 7, 2006 | 11:03 AM
Mbe25's Avatar
Mbe25
it says nothing about replacing the metal that the rust has consumed.
Old Apr 7, 2006 | 11:12 AM
way to make friends here buddy with the way u stated that previous comment h:
but yes u are correct... u have to cut out the rust area, clean the surrounding *i cant remember what the stuff is called but it helps prevent future problems* weld, replace, bondo, sand, etc....
Old Apr 7, 2006 | 01:28 PM
EGhatchback's Avatar
EGhatchback
EGhatchback.com Owner
RWR Sux... go with what MB said
Old Apr 7, 2006 | 02:08 PM
ariza034's Avatar
ariza034
SuMaDiNaC
goo buy a new car lol just kiddin
