Misfire or popcorn popping sound between 2-2,500 RPM
Old 04-08-2006, 02:11 PM
InfiniteVTec
The Dealer
InfiniteVTec's Avatar
Default Misfire or popcorn popping sound between 2-2,500 RPM
I keep getting misfire or something at 2,000-2,500 RPM. I've notice this used to happen once in a great while, but it's been occuring ne time I'm in that RPM range, full throttle or part throttle. Any ideas what it can be? I wasn't sure if this could be tranny related or not.
Old 04-08-2006, 03:35 PM
Wharbone
Wharbone's Avatar
Does it only happen when you are pulling load, like going up a hill? If so, you are probably describing pre-detonation ping.
Old 04-08-2006, 04:26 PM
InfiniteVTec
The Dealer
no, it does it whenever i hit that rev range, whether i'm driving slow or fast.
It's pretty strange to me how it happens at those RPMs specifically.
Old 04-08-2006, 05:32 PM
InfiniteVTec
The Dealer
UPDATE!... I was going to do a compression test, and guess what I found?!
I found 3 spark plugs with the tips broken! wtf, the only 1 without the tip broken off was a spark plug I replaced after I found it with a broken tip. What causes this? my spark plugs are 1 step colder than stock. I'll post pictures, I haven't had piston to valve contact either.
Old 04-08-2006, 05:41 PM
InfiniteVTec
The Dealer
In cylinder order... Left by the Distributor, right going towards the Cam . 3rd cylinder is the 1st spark plug that was replaced alone, which isn't broken, replaced about 15,000 miles ago when it was the only spark plug with a broken tip. I never expected this to happen with the rest of the pack!
Old 04-08-2006, 05:47 PM
Civic2Scooby
Civic2Scooby's Avatar
wrong plug thread length...thus putting the spark plug too far into the combustion chamber and being hit by the piston....dunno its the only thing I can really think of....Try replacing them with the OEM plane jane NGK plugs and see if you have any problems with those. They are super cheap too so it cant hurt.
Old 04-08-2006, 05:51 PM
InfiniteVTec
The Dealer
The thing is... the 1 good plug which I drove 15,000 miles doesn't appear to be damage, the one I had before had a broken tip. Maybe I got defective plugs in that 4 pack? I'm going to Super Autobacs right now and getting them Greddy Irridiums Spark Plugs, they're made by NGK. I can't be having this sh!t in my cylinders it's not worth it.
Old 04-08-2006, 05:52 PM
qtiger
qtiger's Avatar
Greddy iridiums?
:rofl:
Old 04-08-2006, 06:03 PM
InfiniteVTec
The Dealer
Originally Posted by qtiger
Greddy iridiums?
:rofl:
are they bad? they're called Greddy Iridium Tune
http://greddy.com/prod_spark_plugs.htm
Old 04-08-2006, 06:12 PM
Wharbone
Wharbone's Avatar
Just use NGK's dude. Any reason you are running 1 step colder?
Did you torque them to spec? Correctly set the gap?
