Bent Valves! What else should I do..?
Finaly got the timing belt put on the car, and it wouldnt start. so did a compressoin check and no comp on 3 cylinders. so we pulled the head and poured a lil bit of brake fluid in the comb chamber and all the fluid ran through. so A) Bent valves or B) not seating properly. The head is goin to machine shop on mon to get checked out. is there nething i should do in the block while the head is off. its stripped right down to the block. it is a 98 gsr jdm
Your Powder Coater
