bad throttle response
Old Apr 3, 2006 | 04:43 PM
itrdc2's Avatar
itrdc2
Default bad throttle response
hey guys when i step on the padal it tends to not go then go there are no cel on and when im driving it likes turns off thne go
Old Apr 3, 2006 | 05:10 PM
Fkatz's Avatar
Fkatz
date of last tune up if u can't remember or more then 2 yrs u need one most likely it is fuel filter can be the catalytic converter being clogged
Old Apr 3, 2006 | 09:54 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Clogg cats make a rattling sound, even if the exhaust bolts on all tight, and your car will have slow acceleration especially your top end suffers as well.
Old Apr 4, 2006 | 12:13 AM
thecarguy's Avatar
thecarguy
Check your coil, check your cap and rotor, check your spark plugs, check your air filter, check your throttle cable. Have someone sit in the car and press the gas pedal, while they are doing this, look at the throttle plate to make sure it is opening when they step on the gas pedal.
You might also need what is called a fuel injector service. They put fuel injector cleaner in an I.V. looking thing and connect it into a vaccuum source in the engine. Then let it idle. When all the fluid is gone, they connect the line back up and rev the engine. That helps to clean out the injectors as well as the carbon inside the engine. Looks like they blew your head gasket, but it's just burning carbon and injector cleaner. hth
Old Apr 4, 2006 | 12:30 AM
Civic2Scooby's Avatar
Civic2Scooby
check the voltage at the TPS my guess is you have a "hole" in the resistor or it is out of adjustment.
