rubbing
Old Apr 25, 2006 | 06:03 PM
bigaggy's Avatar
bigaggy
Default rubbing
I just got my tires in the mail today. I have 17x7 in wheels with a 40mm offset. the tires I got were size 205/40/17, should I expect to have rubbing on a 96 civic ex coupe, if so what can I do to fix it.
Old Apr 25, 2006 | 06:17 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Is your car lowered? If so how much? You shouldn't rub unless your car is slammed.
randomtask77's Avatar
randomtask77
Wanderer
How low are you dropped? Your wheels and tires are within specs where you shouldn't have a problem. The only thing that I could think of is that you're too low and you have really bad negative camber.
Old Apr 25, 2006 | 11:12 PM
JustaSolVTEC's Avatar
JustaSolVTEC
if you're lowered more than 2", you'll have some problems. 17"s will slow you down as well.
Old Apr 26, 2006 | 12:47 AM
bigaggy's Avatar
bigaggy
I have teins on that I believe are almost 2 in the front and like 1.7 in the rear.
Old Apr 26, 2006 | 01:03 AM
90CvcDX's Avatar
90CvcDX
kekeke
if they are s. tech's then the drop is 1.7 in the front and 1.5 in the back.
Old Apr 26, 2006 | 04:27 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
It doesn't matter (in most cases) how low you are dropped. What matters more is the offset of the wheels.
Autocross Help Page
Old Apr 26, 2006 | 10:20 AM
darkskyracing's Avatar
darkskyracing
hell yeah i put 15's on my 98 ex and the rear rubbed hella bad. but the tires also stick out about a 1/2" but i just took them off and banged the lip or metal in on the outer part of the rim well and that did the trick just fine with no body damage. Well considering that you take your time
Old Apr 27, 2006 | 03:38 AM
bigaggy's Avatar
bigaggy
if I wanted to go any lower than 2in I'd have to roll my fender correct?
Old Apr 27, 2006 | 04:26 AM
CivicSiRacer
Re-read my post again up above.
My experience shows that 40mm offset you may or may not rub. The reason being is that not all company have the best QA (quality assurance) and one company may make a 40mm offset at their company 38mm and another might make it 42mm.
And actually the best width to get with a 7" wide rim is a 42-44mm offset.
Autocross Help Page
