- JRSC Installation
- How to get rear main seal out of its ring?
- question about phantom grip
- Trouble getting crankshaft out of d15b2
- A question-
- Clutch Master Cylinder
- is it possible ???
- Head Gasket?
- Any motor in a 71 N600?
- crvtec superchared
- Speedometer/Wire Harness ?
- Pistons for B16A2
- Big Injectors
- b16a2 in 94 ex?
- Question about A/F Ratio problem!!
- Can Someone Please Help?!?!?!
- Why a high CR for all-motor?
- b16?
- D15B2 Specs?
- up in flames.....literally
- Engine noise...PLEASE HELP!
- b16a1 short blcok w/ b16a2 head & b18 gutts?
- benefits to this?
- Tranny Swap Help!?!?
- Where t buy turbo pipes?
- question about shocks
- A better 'VTEC'
- B16 rods fit on a LS crank?
- eng. coolant temp sensor
- Auto accord to 5pd H22a??
- Compression Ratio?
- Wiring Harness
- Watch out for DPR Racing, Stole $9,000 from me. Thiefs.
- Problems arising.
- A couple of LS/VTEC hybrid questions!!
- Sorry for the other day...so how do I wire a D16Z6 in a '96-'98 EX?
- Check engine light
- b16 crank into b18c1 motor
- Auto standing at signal: In Gear VS Neutral
- Lift for my new garage?
- H22a swap into.....?
- mini me d16y7
- headgasket/adj. cam gear/injectors install
- 6 speed
- You people must not know anything!!!
- d16z6 in 96 civic ex
- crx si....
- AOD (Auto Over Drive) discussion
- rpm's surging up a bit
- Turbo Wastegate question
- What is the bore and stroke...
- low idle probs
- anyone heard of "Monza" BOV's ??
- Starter problems
- which headstuds to use on mini-me (y7.block z6.head)
- RPM jumping and engine sputtering
- Denso IK20 Spark Plugs.
- Help Building My B20VTEC!
- 4th H22 turbo drop in .. Need INFO
- Just ordered my b18... need some help...
- Pics of my ecu
- 94 Accord Trans. Price
- questioning boost on B18B
- Down-Pipe showoff thread
- Exhaust gas in coolant
- timing belt drive pully - how to remove?
- Boosting F22B1 Major Question
- engine light for 2nd o2 sensor
- firing order?
- Vibrating noise in Engine
- new hybrid
- Fastest 1.6l single cam...
- Help Car Won't Start!!
- Darton Sleeve + Block Guard Q
- coolant leaking
- OBX/Ebay Turbo Manifolds
- I need a fluid spec, anyone have a manual?
- Intake Help Please, Don't flame the noob
- PlEASE HELP w/ serious engine problems
- SRS light and engine light problems
- camshaft caps
- help......
- Engine light prob
- ecu pin number ?? or wire ??
- New Engine Question
- whats going on with my clutch
- hydro-lock?
- Car is going cookoo
- EGR Failure
- b17 camshaft cover
- B Series decided... but what setup?
- compression and track numbers
- Exhaust problems
- Building F23 ?'s
- Auto to manual trans swap
- Running too rich?
- gsr in 96 sedan
- Head machining
- Type R in a Civic
- Very confused! PR3? PR4?
- Need help.. suspension?!? 95 Civic
- car won't start, help please!!!!!
- 91 Accord stumble - need some help
- 93 prelude Si H23 - Smoking Exhaust... What's Wrong???
- *idle Problem
- f23a4
- How exactly does an engine knock sound?
- rebuilting my gsr block
- Cel Code 38??? on JDM B16A
- d16y7 into a 90 crx hf
- D16Z6 Swap into a 92 VX
- difference between B16A2 & A3..?
- Serious Engine Probs
- Waterpump Compatibility ?
- differences in blocks
- Car Overheating HELP!!!
- Problems starting in hot weather?
- Engine Rebuilt
- Beginnings of a starting problem??
- Honda Accord Engine Prob
- Timing Chain skipping teeth HELP
- how do i get a CARB sticker??
- Hard cold start prob....
- diesel sound..?
- Intake idle problem
- grinding shifting from 1-2
- new engine in car need help
- Rebuilding H22
- ZC, what's possible?
- Need Help ASAP Please
- Turbo?
- ECU Question?
- clutch not fully engaged??
- Swap Question? ? ?
- who's reputable?
- 92 accord wheel bearing or half shaft?
- Where can i buy a Yellow 2.5" silicon coupler?
- PM6 convert to P28... HELP ME
- b16a2 into 92 civic
- Way to ruin a weekend
- crack RADIATOR
- Differential oil seal for jackshaft question
- sohc vtec swap question
- CEL code P1259 VTEC System Malfunction
- Crazy Ass O2 sensor problem
- axle help
- Car Overheating, Suggestions?
- New Edelbrock Performer X Intake Manifold for D16Y8 engines
- how to check coil....
- S-afc Strange Problems *no Newbies*
- tack install question
- Fluid spills onto my feet while turning.
- squeeky sound from clutch
- LS/Vtec Ecu question?
- noob questions
- good compression to shoot for when building a block
- leaky tranny
- b16 or b18b1
- JapanDomesticMotor.com
- Question for oppinion from a mechanic or someone that is mechanicaly inclined
- where to buy a motor and accesories
- Swapping civic SOHC engine with DOHC engine
- low torque at low rpm
- Changing spark plugs (easy)
- I'm a dummy!
- how to read CEL?
- 93 Integra GSR Won't Start - Suggestions welcome
- problem with vtec controller
- need help, please!!
- radiator ?
- Plasti-Gage sucks
- F-rankenstein engine
- Hondata: what is needed to burn/datalog?
- skunk2 manifold install
- My Prospective turbo B18 setup ?s
- F20B swap
- About SMG...not really honda
- Recommended reading?
- apexi turbo timer questions
- Swap into an HX.
- Radiator options in 5th gen hatch?
- OBX Header.. any good?
- Timing Marks on 89 teg
- h22a Type SH Intake
- ý need PGM-TESTR
- I want All Motor.
- Shaggin' Wagon Engine Swap Help? Replacing a D15B2
- valve cover.
- Exhaust Dump
- 92-95 Project and others
- B20 VTEC Build-up
- Squeel from intake
- o2 sensor wiring help
- Cops
- Engine shake
- Engine degrees
- MAP sensor problems?
- Code 1 primary O2 sensor
- Wiring OBD1 93 B18A ?
- B18C Swap Hesitation...
- Master Cylinder/Brake Booster compatibility???
- Knock Sensor code won't go away
- injector cc's????
- LS Vtec
- JRSC H22 Prelude
- B18C swap wat intake?
- need help with my lsvtec??
- Import Builders Block Need Opinions!!
- no. 9 code in 89 teg.
- Misfiring?? IDLE help!!!
- axle seals
- Again
- 1995 OBD1 JDM B18c
- No ground at ignitor...WTF?
- My Block *pics* (56k u can try)
- Broke H23 Tranny...Now what?
- Idle Question
- b18b to b18c
- 99 Si exhaust
- Good Compression Numbers YAY
- intake question
- help
- 88 Integra LS
- Exhaust velocity/engine bay temps
- Blown Head Gasket or what???
- Is this possible/ better?
- Inline fuel pump wiring
- Questions about CR/cams/milled head/headgasket
- Hey guys first post! How do you do this
- WHere to get a engine Sleeved in CA
- RS-R Exhausts guaging interest
- Deshrouding valves, SOHC
- LSD help?
- stock looking/sounding 2.5-3" exaust
- 98 ls put in 95 civic ex ?
- B18c1 Help!! I don't know which setup to go for!!
- wrong gasket causing my vtec problems?
- b18c5 turbo in 96 civic with 94 integra conversion questions
- h22a vtec problems
- '91 CRX project
- Wiring help
- Mmmm Euro-R Intake Mnaifold
- The Beast crate engine.
- ignition problem
- Swap Question
- What would cause VTEC to drop off in power?
- VAFC pressure signal help and VAFC settings you ppl have! HELP
- Alignment problem, HELP!
