TPS Sensor problem!
Old Oct 3, 2003 | 04:34 PM
civicon19s's Avatar
civicon19s
Default TPS Sensor problem!
A problem that i have been recently having is my car throwing a code 7 (tps sensor). After checking the both the reference voltage and the signal voltage at BOTh the ecu and the sensor itself, i found everything to be in spec. After i reset the ECU, i go to drive the car and it does not throw a code until about 2minutes of driving. what could this possibly be?? any ideas?
Old Oct 3, 2003 | 09:43 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
you running an aftermarket air filter or intake system?
Old Oct 4, 2003 | 10:52 AM
civicon19s's Avatar
civicon19s
Yes i am , although i dont understand how that could possibly make any difference? At any rate i did trace it back to a poor connection which i fixed and later had no problems on the test drive.
civicon19s's Avatar
civicon19s
Old Oct 5, 2003 | 08:55 PM
hondatech's Avatar
hondatech
The oil from the aftermarket filter can cause tps and map sensor codes to set.
