Turbo H22 vs. Turbo B18C1?
Old Oct 4, 2003 | 10:34 PM
HondaFreak6's Avatar
HondaFreak6
Default Turbo H22 vs. Turbo B18C1?
95 low-boost turbo H22 or 95 low-boost GS-R? Which would be faster in 1/4? Also, which would be easier to maintain and tune?, the B18 or the H22, i guess wut im trying to say is.....which car would be more reliable? thank you.
Old Oct 6, 2003 | 01:17 PM
v4lu3s's Avatar
v4lu3s
depends on teh condition of the engine and tuning. an 8psi h22a should be able to make 275 whp though.
Old Oct 7, 2003 | 03:26 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
You would have less of a hassle with just b18c turbo.
Old Oct 14, 2003 | 11:33 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I hear bad things about f and h series trannys.
-PHiZ
Old Oct 15, 2003 | 01:20 PM
twin3037's Avatar
twin3037
the h serie wil make more power but will also be harder to put into the car and wont goaroudn corners as well
Old Oct 18, 2003 | 09:29 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
-PHiZ
My H series tranny is bullet proof...
Unfortunately I have a really dumb ass reason for knowing thish: ... when we put my motor in we all assumed someone had put fluid in the tranny... well no one had and I drove on it for a week with no oil... that's right no oil and I drove it kind of hard a few times that week even though I shouldn't have.
Well I discovered this after fifth gear kept popping out and I thought to check the fluid.. pulled fill bolt and no oil... pulled drain bolt and hardly a drip. Anyhow put oil in it after beating my head on the concrete for an hour or so and it has been 100% fine ever since.
the only problem you should have with one of these trannies and turbo is if you have the stock lsd. But that's only with extreme hp #'s coming off of boost. If you don't have the lsd or do and don't plan to go hog wild with the boost then keep it as is... otherwise invest in a good solid lsd and this tranny will do just fine.:thumbup:
Old Oct 18, 2003 | 09:32 PM
h22avid's Avatar
h22avid
If you know how to properly tune your suspension beyond just struts and springs then the H will handle just fine... plus when you're coming out of the corner.... BWAAAAAAAHHHHHH.....ZOOOOOOOM!!!!!:fawk: :thumbup:
Old Oct 20, 2003 | 11:01 AM
twin3037's Avatar
twin3037
in the end i think the two cars will be about the same in a striaght line prelude will make more power integra will make less buut also weighs less in the end it all comes down to what u like
Old Oct 20, 2003 | 11:06 AM
twin3037's Avatar
twin3037
Old Oct 23, 2003 | 11:29 AM
uoboarder's Avatar
uoboarder
Got Boost? I used to
Default Re: Turbo H22 vs. Turbo B18C1?
Well, installation of the GSR turbo kit would be easier (since I've done both). Let me tell you that the Revhard kit for the GSR is kick ass, but for the Lude...FMAX...just ditch the fuel system they give you and go with a Hondata on both setups.
Maintenance...doesn't matter. They're both turbo'd so you're going to have to do the same things.
Reliability? I'd lean towards the GSR engine because the H series ring lands are prone to cracking more easily. However, it ultimately depends on tuning. If your tuning is really good then they'll both be able to last a while. This does not include acts of stupidity such as dropping 3rd and boosting on the freeway for all of 3rd, 4th, and pulling hard in boost in 5th to see if you can keep up with that Enzo that just passed you.
