Turbo H22 vs. Turbo B18C1?
Old Oct 26, 2003 | 06:00 PM
GsrRex88's Avatar
GsrRex88
Hmm... These opinoins all seem bias.
Heres another one.
Go with the B18C1.
-Eric
Old Nov 7, 2003 | 09:10 AM
scott21's Avatar
scott21
I've always heard that the H-series engines are better for turbo than the B-series. And they're definitely faster, much more horsepower and torque.
Old Nov 7, 2003 | 01:07 PM
twin3037's Avatar
twin3037
but unless your swaping it in the prelude also weighs 300lbs more then the teggy
Old Nov 7, 2003 | 01:09 PM
v4lu3s's Avatar
v4lu3s
ummm
the h22a does NOT weight 300lbs more than a b18c.....
Old Nov 7, 2003 | 01:55 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Weighs about 75 pounds more, from what I've heard. Also, '92-'96 Prelude H-series engines are closed deck blocks, which is definately perfered for a turbo application but still has pistons and rods that were never designed for boost.
Which is faster when modified is such a relative question it's almost pointless to ask. A hacked together H22A swap with the wrong sized turbo and crappy if any tuning will get it's ass handed to it by a properly perpared and well tuned B18C1. Despite what technology has to offer, the old saying "there's no replacement for displacement" still holds true though. Personally, I'd go with a B18C1. Better aftermarket support, motor fits without modification and more people have done it before you so they figured out most of the problems.
Old Nov 7, 2003 | 02:21 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
Can we say apples to oranges? I don't undertand your logic or lack there of! How could you possibly compare a "hacked together H22A swap with the wrong sized turbo and crappy if any tuning" to a "properly perpared and well tuned B18C1". That just makes no sence what so ever and is quite ignorant if you ask me. Lets compare apples to apples... a properly perpared and well tuned H22 can and WILL stomp the shit out of a "properly perpared and well tuned B18C1".
There are plenty of turbo kits made specifically for the H22 so how one could screw that up is beyond me.
With mounts from hasport, place, hcp, enjo, etc. the H22 is a straight bolt in swap just like any other motor. As for modifications needed to put the motor in... that is just not true. There is no modification but rather the removal of the passenger side frame rail mount.... and really it doesn't have to be removed completely... it can be cut back an inch or two so that it doesn't interfere with the shifting mechanisms on the tranny.
Trust me when I say this. I have the H22 in my civic and a buddy that lent me a hand putting my motor in who has done plenty of B-series swaps said mine was just as easy as any other swap he has done.
As for weight, that is another null issue. As stated previously the H is only 75lbs more than a B. Put your battery in the trunk as I have done, get a cf hood, lighter wheels, etc. and the weight difference is hardly earth shattering. We're not talking about weight differences like exist between a domestic and an import but rather a 30 - 40lb max difference after some weight management between the B and H. I think the displacement, torque, and whp, of the H especially a boosted H more than makes up for any weight difference. :thumbup: :fawk:
BTW... I would definitely recommend the hasport mounts over any other available.
Old Nov 7, 2003 | 02:31 PM
v4lu3s's Avatar
v4lu3s
one thing to consider is the fact that there are a LOT more properly built and tuned b18c turbo setups than h22a. most h22a turbo setsup i see ARE hacked together.
Old Nov 7, 2003 | 02:47 PM
h22avid's Avatar
h22avid
I've seen plenty of hacked together B's and D's too. A turbo is a turbo... there's no real big differnce from one setup to the next besides who puts it in.
Like I said, there are turbo kits readily available for the H22 so how someone could screw that up is beyond me.
The only thing you have to be careful of his how much boost you cram through your intake before you get to the level of having to build up the internals to handle it.:thumbup:
Old Nov 7, 2003 | 03:42 PM
v4lu3s's Avatar
v4lu3s
you havent seen what 10 psi porrly tuned can do on the pistons of an h22a.
i have seen melted pistons on 14 psi
Old Nov 7, 2003 | 04:11 PM
Andy's Avatar
Andy
I didn't make my statement for a comparison of B18C's and H22A's, but rather in halfassed turbo vs proper turbo setups. Also, no offense, but either engine when properly turboe'd and tuned can make enough horsepower that traction is more of an issue than power (we're talking about street cars here). I think 2 equally built engines, one of each, would come down to suspension, tire and driver skill (on street tires, they'd both probably low 12, high 11 cars).
You can have the most complete turbo kit in the world and still blow your engine to pieces, I think we've all seen that before.
