• Integra Tech: [Read and post your basic questions here.]
There is a fuse for everything electrical, but it may not be a dedicated circuit. I don't have my manual handy so I can't point you in the correct direction, but start looking for anything else that may be not working. Look for other low-voltage lights, wipers, radio, etc. Someone here can probably tell you which circuit it is, but if you don't get a reply, post it as it's own thread in the main Integra forum.
Do they blink if the hazard button is pushed? Are the bulbs good? Have you taken a multimeter to see if there is a current reaching the bulb?
Yeah the bulbs are good and everthing. I pushed the Hazard light one time and damn thing flashed once then went dead....no more flashing. I asked one of my homiez & he was like its probably the Flasher plug that blew out, he said itz a whole seperate plug thats right next to the fuse box, I'm just asking here cuz I wanted a second opinion to see if that'z most likely the reason. But thatnks 4 the reply though.
The gaskets and seals should be the same, however the 86-87 vacuum advance distributor may not bolt to the 88-89 (electronic advance distributor) head.
ok im putting my coil overs on today, and the bottom bolt on the back strut that hold the strut fork to the swing arm i cannot get them off, i've tried everything i can think of, ratchet with breaker bar,impact gun.. anyone else had this problem and what did u do? please help
ok i have a 94 integra ls with a horrible double pinstripe down it. i have been told it is painted but the research said it is not anyone have a clue how to get the damn thing off???? pleasse PM me with the answer also
i was driving my 96 integra down the highway and my engine died. a few people i spoke to suggested it may be a problem with timing chain. i really don't know much about cars anybody with some info in this area would be greatly appreciated.
They are dealer options and are not painted over. Try to scrape them off with your fingernail or use a hair dryer to soften it and try again... they don't come off easily.Integras have timing belts, not chains. Timing chains rarely brake, timing belts will if not changed as per the owner's manual.
