• Integra Tech: [Read and post your basic questions here.]
Old Apr 14, 2006 | 12:27 AM
  #111
90rsTeg's Avatar
90rsTeg
weapons of the revolution
opps.
Old Apr 14, 2006 | 12:38 AM
  #112
90rsTeg's Avatar
90rsTeg
dont just"add" fluid. Find your fill level plug! With the wheel all the way right you can remove a mud guard to get at the trans. The fill plug is hex, the drain is a box. Fluid can be added through a vent in front of the distributor on the top of the trans. housing. This will have a black cap on it. There are many threads on this funnel to hose to vent fill method. Now add fluid until you reach the hole in the side of the transmission and it comes out.
Old May 3, 2006 | 09:41 AM
  #113
Vtec racer's Avatar
Vtec racer
life begins at 6500 RPM
i have a 1994 gsr 4dr i wanna swap the engine but i dont know with what (to many chioces) right now im leaning twoards the b16a im going ot turbo it so any comments would help thanks
Old May 3, 2006 | 09:53 AM
  #114
sherwood's Avatar
sherwood
I missed Sean
are you serious?
Old May 19, 2006 | 01:50 PM
  #115
94blueteg's Avatar
94blueteg
screwed
how would i go about separating the driver's side cv axle from the output shaft? it looks like something that you have to pry apart, judging by how it looks, but i dunno. by the way, the axle is in two pieces at the moment, inner cv joint came apart. thanks guys
Old May 21, 2006 | 05:18 AM
  #116
gtpblax11's Avatar
gtpblax11
can anyone gimme some help or reasons of why me maintenance light came on...plz reply....thnx
Old May 21, 2006 | 05:42 AM
  #117
Nors's Avatar
Nors
倍力恋
https://www.honda-acura.net/forums/s...0&postcount=13
Old May 21, 2006 | 02:17 PM
  #118
gtpblax11's Avatar
gtpblax11
thnx...i looked in the manual too n saw that n did it honestly 20 minutes after i posted this....but thnx for the response, really appreciate it
Old Jun 5, 2006 | 08:49 PM
  #119
kevyt's Avatar
kevyt
I need to do a valve adjustment on my GS-R. Derek said there's a special tool I need first, which is only for the GS-R, is that correct?
dom93hatch,
I believe this posting talks about adjusting the valves. https://www.honda-acura.net/forums/s...d.php?t=219739
I do not recall what the posting says but I think you need a 10mm box end wrench that is bent so it will reach down onto the nut that is on top of the spring. You will also need a bent feeler guage and a flat screwdriver.
Someone at Karen Radley Acura in Baley Crossroads, Virginia, told me a few weeks ago that he did NOT recommend adjusting the valves unless they are making noise.
Mine has 218,000 miles and I have not adjusted mine.
Old Jun 5, 2006 | 09:29 PM
  #120
Kai's Avatar
Kai
Rotorphile.
Once the axle is loose from the hub, you do pry it apart.
There is a special tool that helps do valve adjustment jobs... imagine a 10mm wrench with a screwdriver stabbed through it. Still, bent feeler gauges are a must.
I also advise not to adjust them unless they are ticking or about 60k miles have past since the last adjustment.
