• Integra Tech: [Read and post your basic questions here.]
Old Dec 12, 2005 | 07:23 PM
  #91
98 integra's Avatar
98 integra
alright i have two questions... one about how much do the antenna motors for a 98 integra cost... #2 the back hatch shocks are broken and i tryed to remove them.. they will come off the hatch but i cant get them off the main body without breaking something.. plz help.
Old Dec 12, 2005 | 08:27 PM
  #92
sherwood's Avatar
sherwood
I missed Sean
http://www.acuraautomotiveparts.org/...catcgry4=KA5MT
you should be able to find what you need in there
i think the motor is under radio antenna/speaker
not sure about the hatch shocks tho
Old Dec 13, 2005 | 08:36 AM
  #93
bnuk's Avatar
bnuk
If I remeber correctly there are retaining rings holding them on to the car. kinda like the ones in this picture.
you will need to rotate it so the opening is facing up and then push the two ends down and apart with some needle nose pliers until it pops off.
File Type: gif
Old Dec 15, 2005 | 06:56 PM
  #94
Austin01GSR's Avatar
Austin01GSR
I have a 01 GSR and I'm trying to replace the rear bumper clips. Any advice on how to get these off??
Old Jan 10, 2006 | 08:54 PM
  #95
93acurateg's Avatar
93acurateg
Default 93 Acura spuddering
i have a 93 acura integra and when i start it up it idiles at 1 1/2 grand but when it warms up it drops to about 200rpm and just stays thier. Then when i rev the engine it spudders alot. The RPMs have a hard time climbing up i already changed the fuel filter, spark plugs, spark plug wires and the disributer. also had to put it to tdc and then set the disributer to 180. but still acts up if can help me with this prob please answer.
Old Jan 11, 2006 | 07:16 AM
  #96
Kapa6ac's Avatar
Kapa6ac
alright i have two questions... one about how much do the antenna motors for a 98 integra cost... .
Check this site:
http://www.antennamastsrus.com/Acura...01990-2001.htm
I'm going the to order the antenna mast from them ...
cheers,
Kapa6ac
Old Jan 21, 2006 | 04:17 PM
  #97
muchswatch's Avatar
muchswatch
Hi all, a quick question, is the 96 Integra GSR Milano mirror fit to 95 RS? Thank you
Old Jan 29, 2006 | 01:35 AM
  #98
DA808TWITCH's Avatar
DA808TWITCH
Default Suspension Help!
I have a 90 Integra, so I ordererd 90-93 Integra shocks. What I got was 94-01 shocks by Tokico. When I got my shocks, the part numbers on the shocks did not match the part numbers that I had ordered. When I looked up the part numbers online all the web sites list the shocks I got as 94-01 shocks. Yea the company sure screwed up.
The problem: this is my only week off from work....the only time I can do my suspension, thus sending my shocks back and waiting for the right one's would be useless. My quesion is can they fit? I herd that the front shock is exactly the same. As for the rear, I measured it today and the Tokico shock is approx. 1cm longer from bottom of the spring to the bolt insert.
Please let me know if it will work, and if there will be any sideaffects do to using the wrong shock.
Thank you for all your info!
Old Jan 29, 2006 | 12:37 PM
  #99
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The 94-01 shocks will not fit properly; I strongly recommend resolving the issue and waiting for the correct set of shocks.
Even though the difference in damper length in minimal, you run the risk of bottoming out the rear suspension due to decreased piston travel. If that were to happen in a fast turn, you'd have a very sudden onset of oversteer.
I know it's a hassle to wait, but don't take the risk.
Yes, the bolt patterns are identical. You can also dissasemble and paint your RS mirrors to match the color of the car.
Old Jan 30, 2006 | 02:13 AM
  #100
bnuk's Avatar
bnuk
or, you can just paint them black, might sound a little weird, but i did mine black and it looks perfectly normal, no one has ever noticed it. A lot of cars have black mirrors.
