• Integra Tech: [Read and post your basic questions here.]
Hey guys,
I have a four door generation 2 integra (91) gs-r auto trans.
The back-up lights don't come on. I checked the bulbs, and the fuse, they are fine. What else could it be? Does this thing have a back up light switch on the trans? Or is it that for manuals only? I know that the auto's also have a transaxle gear position switch, dunno if that could be it as well.
Also, the really annoying thing, now it will not shift out of park into R, N, D, etc, unless I stick the key into the shiftlock release whole on the shifter. It started happening 1st when I had my wife shifting it into reverse and park a bunch of times (checking voltage to fix the reverse lights). She me have shifted it without putting her foot on the brake pedal. Dunno if that matters.
Any ideas? Yeah, yeah,
I know "get a manual"
Thanks in advance!
Mike - G
pics
Thanks in advance!
Mike - G
pics
i was wondering i have a 90 integra and i have a after market tack that says the car will rev to 8,000 or 9,000 rpm but it wont cuzz its set stock at i think 6 or 7,000rpm be for it hits the rev limiter i dont want to float a valve? so how much would it cost to put stonger valve springs in so i could rev out to 8,000?
Secondly, it's not just the risk of valve float that determines your redline. The con-rod main bearings are not designed for constant use above 7000 rpm. If you want to build your B18A1 motor for continual high-rpm use, there are a series of upgrades that have to occur to preserve a reasonable level of reliability.
That said, there are cams available for the B18A1 that would justify the expense of stronger valve springs and retainers, while still making power in the rpm range your OEM con-rods can handle. Start by looking at Crower Cams.
