• Integra Tech: [Read and post your basic questions here.]
Old Feb 26, 2006 | 07:07 PM
  #101
nightrise420's Avatar
nightrise420
94 Integra LS Maintenance. There is a slight oil leak in the engine. I think it's due to gasket. It's a tiny oil leak. Is there a way to check it if theres anything wrong?
And i wanna know how to maintain the paint job.
Old Feb 26, 2006 | 10:07 PM
  #102
sherwood's Avatar
sherwood
I missed Sean
uh... yeah theres something wrong... you have an oil leak.
as for the paint just wash it by hand using products supported by the guys over at www.autopia.org
Old Feb 27, 2006 | 05:48 PM
  #103
nightrise420
well, what do i use?
Old Feb 27, 2006 | 05:54 PM
  #104
sherwood's Avatar
sherwood
I missed Sean
it really depends on what you want to use for the paint surface...
i choose to hand wash with microfiber mitts, and dry with a microfiber towels.
as for wax i havent really gotten around to it, but there any a full review section on autopia that covers it. i use spray wax every other time i wash to help keep up so far..
really everything for your finish needs is on www.autopia.org
now the oil leak with require a new gasket (if thats infact what you need)
if its a head gaset leak buy a head gasket... its really realitivly simple to figure out what you need it's doing it thats the hard part.
Old Feb 28, 2006 | 08:25 AM
  #105
nickgsr's Avatar
nickgsr
Having problem with a VTEC controller setting a VTEC system faliure trouble code on my 1996 GSR can you help
Old Mar 8, 2006 | 02:01 PM
  #106
AcuraGirrl23's Avatar
AcuraGirrl23
hey....im needing some help with replacing my distributor...and also..about a timing light......yeah as you can tell im clueless..so fill me in...ok thanks!!
Old Mar 16, 2006 | 03:41 PM
  #107
mrproul's Avatar
mrproul
THESE ARE THE OBD-1 CHECK ENGINE CODES
MIL
Engine Control Module (ECM/ECU)
Heated 02 sensor
3
Manifold Absolutre Pressure (MAP Sensor)
4
Crank Shaft Position Sensor (CKP Sensor)
6
Engine Coolant Temperature (ECT Sensor)
7
Throttle Position (TP sensor)
8
Top Dead Center Position (TDC sensor)
9
#1 Cylinder Position (CYP sensor)
10
Intake Air Temperature (IAT sensor)
13
Barometric Sensor (BARO sensor)
14
Idle Air Control Valve (IACV sensor)
15
Ignition Output Signal
16
Fuel Injector
17
Vehicle Speed Sensor (VSS sensor)
19
Lock Solenoid Valve (A/T trans)
20
Electrical Load Sensor (ELD sensor)
21
VTEC Solenoid (VTS)
22
VTEC Pressure Switch (VTPS sensor)
23
Knock Sensor (KS)
30
A/T FI Signal A
31
A/T FI Signal B
41
Heated 02 Sensor
43
Fuel Supply
Old Mar 16, 2006 | 07:22 PM
  #108
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by mrproul
THESE ARE THE OBD-1 CHECK ENGINE CODES...
:cheers: Thank you very much for contributing.. I've added these codes to the Integra FAQ as well, giving you full credit (it's only right.)
Many thanks. :goodjob:
Old Mar 20, 2006 | 11:45 AM
  #109
dom93hatch's Avatar
dom93hatch
more meat, more fire
I need to do a valve adjustment on my GS-R. Derek said there's a special tool I need first, which is only for the GS-R, is that correct?
Old Mar 22, 2006 | 04:44 PM
  #110
huythaobonbon's Avatar
huythaobonbon
Default how to remove 90 integra headlight
nothing wrong with the headlight, but i just want to clean the inside, look very tuff to remove, after i losing 3 bolts on top of the headlight bracket but it is still very tight, there is any more bolt around. Help me!!!!!!!!!!!!!!!!!
