Hi workout crew, how's it going?
Seated rows- with the dual handle extension or the straight bar
bent over rows
dead lifts
pull ups
I just started back at this gym. I use to be a member there before I moved to SD but they have remodeled since then. I havent seen a hyper extension setup there hence not in my workout
bent over rows
dead lifts
pull ups
bent over rows
dead lifts
pull ups
bent over rows
dead lifts
pull ups
Do Pull Ups first for a while, DL's, Bent Rows, Seated rows, in that order.
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
Im going to rant:
What is it with people who dont know how to spot? I usually lift by myself and I have to ask someone i usually dont know for a spot. I try to be nice and say "if I do need help just give me the slightest help possible"
Then I will be on my last rep, pushing as hard as i can and I will stop about middle way and they will use too much force to lift it up and the last rep was rendered useless. Thanks alot
Im going to rant:
this is why i rarely go alone. i have several friends who know how to make me get the most out of my workout.
Im going to rant:
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
I usually go alone also. Has anyone ever tried doing bench press on the smith machine so that when you've gone to failure you can catch the bar on the latches? I know its not the same as a free weight bench press cause I can lift significantly more on the smith machine
I wouldn't bench on the Smith Machine personally, I know Brett does. I think it leads to shoulder problems as well as not giving you enough stabilizer strength.
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
How would it lead to shoulder problems? Isn't it the same motion as a normal bench press? I could see that you would not get the same stabilizer support. Thats why I like to use dumbells because you have to control the weight all the way down and all the way up
