Engine Swap
Old Feb 22, 2006 | 07:42 PM
  #31
Brad's Avatar
Brad
wooo nascar!
Originally Posted by Driverman5777
What do you think is better?
well, that theory is based on using stock pistons. if you lower the compression of the GSR motor you could run (in theory) however much boost you want. same with the LS. the former owner of a local shop in cockeysville (mike dowell) was pushing 7xx wheel on his built GSR @ 30psi, and a friend of mine that worked with me at acura had a built h22 pushing 740 but i dunno how much boost.
  #32
AcuraFanatic's Avatar
AcuraFanatic
Out of all possibilities what would be the best setup in terms of reliability and power?
Keeping a budget in mind..
GS-R, just find someone who can tune well, and do proper management. If you install and AFC hack or E-Manage or some garbage like that I shall stab you.
Old Feb 22, 2006 | 07:44 PM
  #33
Driverman5777's Avatar
Driverman5777
However woulden't I have to wait longer to kick some asses because by the time I turboed I would have dropped about 8g's
  #34
Brad's Avatar
Brad
wooo nascar!
honestly....
i'd buy a b20 or b18b longblock for cheap and build it for boost. your LS tranny is better than a GSR tranny for turbo anyway. just get a nice clutch and keep your stock flywheel. and make sure you get a good fuel setup.
theres tons of parts and knowledge about turboing and tuning b series motors, and LS/b20s are less expensive than GSRs.
Old Feb 22, 2006 | 07:46 PM
  #35
AcuraFanatic
Originally Posted by Brad
honestly....
I much rather have a GS-R tranny than an LS tranny if given the choice. You'll be in boost longer on an LS transmission because of the longer gearing, but a GS-R transmission will always be faster with the shorter gearing.
Misconception FTL
Old Feb 22, 2006 | 07:47 PM
  #36
Driverman5777
I have an automatic tranny, but I just bought a GSR tranny for a swap. So I am getting ready to do that. I also have a stage 2 clutch and fly.
Old Feb 22, 2006 | 07:50 PM
  #37
AcuraFanatic
And...a lightened flywheel is still a good idea. A heavier flywheel is still parasitic loss that the engine has to deal with and has to fight the intertia of the flywheels weight. The turbo is going to only spool so fast regardless but anything helps.
Old Feb 22, 2006 | 07:53 PM
  #38
Brad's Avatar
Brad
wooo nascar!
Misconception FTL
i guess it depends on how much boost you're actually running. on relatively low boost, a gsr tranny would be better. but i'd think on high boost, you'd blow through the gears too quickly. i dunno, i dont have any tangible proof on that one.
Old Feb 22, 2006 | 07:54 PM
  #39
dubcac's Avatar
dubcac
I
Built, high comp crvtec, ballbearing turbo, aem ems....if I only had about 8 grand to play with.
  #40
dubcac's Avatar
dubcac
I
Shorter gears always equals better acceleration.
