Engine Swap
Old Feb 22, 2006 | 07:36 PM
LT's Avatar
LT
The deer had to die!
I personally would go the B18C1 route (for cheap), build that for boost, then kill everyone one the road.
Old Feb 22, 2006 | 07:37 PM
Brad's Avatar
Brad
wooo nascar!
Originally Posted by airon
k20 > *
good call
the h22 is nice but i dont like the idea of cutting a giant hole in my frame to run the cables for the shifter up into the cabin and whatnot. :wiggle:
that, and how low the engine sits in the bay. if you lower the car too much, you'll rip your oil pan off in a hurry if you're not careful.
Driverman5777's Avatar
Driverman5777
k20 > *
K20 is a very expensive swap not too mention everything is ass backwards.
Old Feb 22, 2006 | 07:38 PM
AcuraFanatic's Avatar
AcuraFanatic
k20 > *
Not $3,000 or under :happysad:
Brad's Avatar
Brad
wooo nascar!
Originally Posted by Driverman5777
53xxx LS. I kinda woulden't mind having Vtec. Plus if things aren't done right w/ a Turbo things can get pretty hairy
you can run higher boost on an LS than a GSR, or you can run less boost and have vtec.
Driverman5777
Originally Posted by Brad
good call
Why would I have to do all of that?
Old Feb 22, 2006 | 07:39 PM
Driverman5777
What do you think is better?
Brad's Avatar
Brad
wooo nascar!
h22 uses a cable system for the shifter, as apposed to a linkage system like b series engines use.
Old Feb 22, 2006 | 07:40 PM
Driverman5777
Out of all possibilities what would be the best setup in terms of reliability and power?
Keeping a budget in mind..
Old Feb 22, 2006 | 07:41 PM
AcuraFanatic
Equivalent setups with the same turbo on less boost, the GSR will always make more power than an LS.
