Engine Swap
Old Feb 22, 2006 | 07:54 PM
  #41
Driverman5777's Avatar
Driverman5777
So should I just stick w/ my engine, Go ls/ Vtec, or swap in a GSR, B16a, H22, or Any other engine?
And then after that is situated go turbo
Old Feb 22, 2006 | 07:55 PM
  #42
Brad's Avatar
Brad
wooo nascar!
Originally Posted by dubcac
Built, high comp crvtec, ballbearing turbo, aem ems....if I only had about 8 grand to play with.
why high compression?
  #43
Driverman5777
I wish I had 8 grand to play w/ 2
Old Feb 22, 2006 | 07:56 PM
  #44
Driverman5777
Do you like blowing up engines?
Old Feb 22, 2006 | 07:57 PM
  #45
dubcac's Avatar
dubcac
I
Originally Posted by AF
Uh yeah, don't do a B18C5 if you wanna run boost. Do a B18C1, even built ITR engines tend to like to go boom after a while, even with a good tune. People get greedy with the boost.
Neither engine is really well suited for crazy boost anyway. H22 suffers from thin cylinder walls and the usual shitty open deck block design, but nothing a set of sleeves can't fix. h:
The compression ratio of the B18C5 isn't much different than the C1...people are just stupid and run FMU's.
Originally Posted by Brad
you can run higher boost on an LS than a GSR, or you can run less boost and have vtec.
Not true...it's all in the tuning. A competent tuner and a good EMS/fuel setup goes a long way.
  #46
AcuraFanatic's Avatar
AcuraFanatic
High compression and boost =/= blowing up engines
Understanding effective compression and knowing how to tune fuel and spark using a high static compression ratio = insane horsepower
  #47
dubcac's Avatar
dubcac
I
No, I like going fast.
Old Feb 22, 2006 | 07:58 PM
  #48
LT's Avatar
LT
The deer had to die!
Just buy the GSR engine already. I loved my GSR motor with a passion. Damn do I miss revving out to 8100 RPMs
  #49
Driverman5777
Yea I'm stuck at 6900 it sux balls.
Old Feb 22, 2006 | 08:00 PM
  #50
Brad's Avatar
Brad
wooo nascar!
yes, you are absolutely right. it is entirely possible with a good tuner. however, they are difficult to find
