Engine Swap
Old Feb 22, 2006 | 07:29 PM
AcuraFanatic's Avatar
AcuraFanatic
Originally Posted by Driverman5777
I'd like to make sure I have everything the way I want it before I turbo it. Because I don't wanna end up changing that.
Uh yeah, don't do a B18C5 if you wanna run boost. Do a B18C1, even built ITR engines tend to like to go boom after a while, even with a good tune. People get greedy with the boost.
Neither engine is really well suited for crazy boost anyway. H22 suffers from thin cylinder walls and the usual shitty open deck block design, but nothing a set of sleeves can't fix. h:
Old Feb 22, 2006 | 07:31 PM
Brad's Avatar
Brad
wooo nascar!
yeah, like i said.. a little bit heavier.
the extra 400 ccs are nice to have, in any case.
and im gonna second what shawn said. neither the h22 or the c5 are really built for turbo. i'd say b20 vtec turbo ftw.
Driverman5777's Avatar
Driverman5777
indeeed but I dnt think I'd boost it for a few years. College comming up... But a H22 would def. make the car faster. Could I get everything from Hasport?
Old Feb 22, 2006 | 07:32 PM
Driverman5777
Woulden't a B20 be good to sleve anyway and woulden't tht cost more? I wanna stay around 3k
Old Feb 22, 2006 | 07:33 PM
AcuraFanatic
What's your goals with this engine anyway? If you don't want to build it and get the maximum horsepower out of a stock blocked engine you can, I'd shoot for a GS-R.
The B20 is a good platform too, but it again has thin cylinder walls.
Brad's Avatar
Brad
wooo nascar!
why not build your LS for boost? your car is an 01, whats the mileage on it?
AcuraFanatic
Good sleeve job installed is about $1,000.
97civicEXVTEC's Avatar
97civicEXVTEC
I'm pretty sure Hasport will have everything you need.
Old Feb 22, 2006 | 07:34 PM
Driverman5777
53xxx LS. I kinda woulden't mind having Vtec. Plus if things aren't done right w/ a Turbo things can get pretty hairy
Old Feb 22, 2006 | 07:35 PM
airon's Avatar
airon
AARONNOJIMA.COM
k20 > *
