Wireless network help
Old Oct 28, 2003 | 08:24 PM
TeggerLS's Avatar
TeggerLS
Originally posted by Black2000GSR
I'm guessing you're using the access point to get the signal from the wireless router in the basement to the wired router in your room and then to your PC.
The access point should be hooked up the WAN port on the router. Then configure the access point to get it's signal from the router downstairs (channel, SSID, WEP, etc..) and have the router set to obtain IP automatically ('cause your downstairs router connected to the DSL modem should already be taking care of the PPoE crap).
Wouldn't it have just been easier to get a wireless PCI card for your PC and hook the access point to that?
I configured it all like you said but still getting nothing:thinking: :happysad:
Do I have to clone the mac id from the AP for the router maybe?
Old Oct 28, 2003 | 08:26 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
why do you have 2 routers?
Black2KGSR's Avatar
Black2KGSR
did you connect the access point straight to your PC to see if you could get a signal...then we'll know if it's a router configuration problem or not.
If you don't get a signal that way either, take the access point to the basement and use it on a PC there, see if you can get a signal.
Old Oct 28, 2003 | 08:27 PM
Black2KGSR's Avatar
Black2KGSR
one in basement to transmit wireless signal, one in room to distribute signal to 3 PCs.
Old Oct 28, 2003 | 08:32 PM
flipped cracka
just making sure. basically using it as a switch then. is the second router hooked up to the network already? i think the WAP has to be hooked into a live network, not get used to connect two points. so the wap would be plugged into the router downstairs for you to get signal upstairs. i believe that's the point of the wap (make a wired network wireless, not extend a wireless network).
Old Oct 28, 2003 | 08:34 PM
flipped cracka
ok, i looked it up. it has to be in bridging mode. but it looks to me like it needs another wap to connect to (not sure if the router would do it). here's what i'm going off of. http://www.linksys.com/products/disp...id=501&scid=35
TeggerLS's Avatar
TeggerLS
how do I test it? to hook it up directly I have to use a x-over cable correct?
Old Oct 28, 2003 | 08:37 PM
Black2KGSR's Avatar
Black2KGSR
Looks like either one of those modes will do.
Old Oct 28, 2003 | 08:38 PM
Black2KGSR's Avatar
Black2KGSR
wouldn't a regular Cat5 cable work? :dunno:
Old Oct 28, 2003 | 08:47 PM
TeggerLS's Avatar
TeggerLS
nopeh: no lights go on w/ regular cat 5:thinking:
Damn bestbuy ppl:madfawk: their pc guru's are teh suckerages
y hath teh intraweb forsaken meh
maybe it woul work if I put the access point in the basement w/ the wired router and took the wireles router upstairs??? :dunno:
