Wireless network help
Old Oct 28, 2003 | 08:52 PM
  #31
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
have aim? i downloaded the user guide, i might be able to walk you through it.
Old Oct 28, 2003 | 08:55 PM
  #32
Black2KGSR's Avatar
Black2KGSR
Originally posted by TeggerLS
nopeh: no lights go on w/ regular cat 5:thinking:
Damn bestbuy ppl:madfawk: their pc guru's are teh suckerages
y hath teh intraweb forsaken meh
maybe it woul work if I put the access point in the basement w/ the wired router and took the wireles router upstairs??? :dunno:
I'm looking at the user guide for the access point, and it says it has to be hooked up to a hub, switch or router...but it doesn't say to which port.
check and see if your router is set to Gateway mode or Router mode...put it in router mode if it isn't.
I just read that you do need a crossover cable to connect it directly to your PC.
  #33
flipped cracka
ok, read the guide. to do what you want to do with it, you HAVE to have another WAP and put them both in Wireless Bridge mode. you can't use the router to do it, and it kinda makes it not wireless (works as a bridge, not a wap).
Old Oct 28, 2003 | 08:59 PM
  #34
Black2KGSR's Avatar
Black2KGSR
Q: Why does the Access Point not obtain the IP address via DHCP?
A: The WAP11 Access Point uses an IP address for SNMP configuration purposes only. This address must be static.
:dunno: if that might help.
Old Oct 28, 2003 | 09:02 PM
  #35
Black2KGSR's Avatar
Black2KGSR
but in the diagram you posted before, it has what he wants to do without them being in bridged mode.
  #36
flipped cracka
maybe you can use it as a Wireless repeater. you have to log into the wap though. that would mean pc to wap (with a ca5 cable. not sure if it should be a xover or patch though).
Old Oct 28, 2003 | 09:04 PM
  #37
flipped cracka
but that also has 2 waps.
  #38
Black2KGSR's Avatar
Black2KGSR
has to be crossover. But it says if he uses it as a repeater, he needs another WAP.
  #39
Black2KGSR's Avatar
Black2KGSR
that's 'cause the first router isn't wireless. the first WAP is just there to send the wireless signal.
it says the second wap is in access point client mode...check and see if there's some kind of setting to put it in client mode. :dunno:
Old Oct 28, 2003 | 09:06 PM
  #40
TeggerLS's Avatar
TeggerLS
wireless repeater require' a mpped mac i. Do I use th mac id from the router in the basement? I'm givin up for tonight, I'll call linksys tomorrow and if they say it won't work I'm going back to best buy and getting a full refund no 15% re-stocking fee crap. they told me it would work.
