• Integra Tech: [Read and post your basic questions here.]
Old Dec 4, 2006 | 12:27 PM
  #161
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by sherwood
whats the difference between the obd-I and OBD-II p75? wasnt there an OBD-I p75?
Yes, there was an OBD1 P75. It is just like the P72 which was available in OBD1, OBD2a, and OBD2b. I believe the fuel and ignition maps are identical, but the sensor control is different.
Old Dec 5, 2006 | 03:21 AM
  #162
perrotto's Avatar
perrotto
B18C1
OBD IIA/P75...Thanks guys.:bigok:
Old Dec 6, 2006 | 11:29 AM
  #163
sanchito7's Avatar
sanchito7
I owned a 96 GsR and recently it is overheating I notice that the cooling fan is not working, I check the motor on the fan- it works, and when I turn on the AC it does not turn on not only the condenser fan turns on. I changed the fuse from the heater to the cooling fan (same fuses) locate next to the battery and now it will work only when the AC is turned on. Also my GsR is making some noise behind the engine when is idle and in low speeds but when I press the clutch it stops. Please help!!!
Old Dec 27, 2006 | 11:18 AM
  #164
jesusublime99's Avatar
jesusublime99
Originally Posted by The Kid
Anyone know the average price that I would have to pay to get my axles changed? My 1991 is running real rough on them right now, thanks.
Average price low price in my area is about $120-150 per axle replacement. The price of the axle itself is a variable of the price.
Old Jan 3, 2007 | 10:28 PM
  #165
88'CRX's Avatar
88'CRX
k i got a b18a motor and trans in my crx.... i need to replace the clutch but dont know what year the motor is from a 90-91 or 92-93.. is there an obvious way to find this out?? and in reading the integra faq i saw that there isnt really a cel decoder section for the 90-91 and the last time my car was in to my mechanics hands he said that he could not check my cel for some reason... does this mean i have a 90-91 or is that jst mean my motor was not swapped completly right???
Old Jan 11, 2007 | 09:50 PM
  #166
The Krammit's Avatar
The Krammit
Default Removing headlight bulb from 93 Integra
Earlier tonight I spent 30 minutes trying to figure out how to remove the bulb from the harness. I got the bulb out of the housing but I couldn't see for the life of me how to remove the bulb from the harness. It looks like there's a clip holding the bulb but I didn't see any way to lift or remove it without potentially breaking something. Also didn't help that it was dark.
Old Jan 16, 2007 | 06:01 AM
  #167
gsr2k's Avatar
gsr2k
Did you try pulling it straight out?
Old Jan 19, 2007 | 10:41 AM
  #168
ArtemisKneptune's Avatar
ArtemisKneptune
Default Rear Hatch Lift Supports
About a month ago I experienced some pretty extreme (for the area; Northwest WA State) cold weather with temperatures well below freezing. My '98 GSR weathered it very well and I got a huge kick out of driving past any number of AWDs and SUVs spun out in the ditch. However, I made the mistake of opening my rear hatch when it was about 5F outside which destroyed my hydraulic lift supports! After I got done cursing myself out I went online to see if I could find some available at a price that wasn't ridiculously absurd. Turns out I can't find them at ALL! Seems to me like a pretty commonplace type item to need to be replaced. Let me tell you, that hatch (w/ spoiler) is one HEAVY mother when you're trying to unload groceries and it keeps falling on your head. Anyone have suggestions for where to look besides going to the dealership and shelling $150 a pop (if they even have them)?
File Type: jpg
Old Jan 19, 2007 | 10:46 AM
  #169
Provocateur
On permanent hiatus
www.acuraparts247.com has them for $60 a piece. Part number is: 74820-ST7-326
You could also search around for people parting out cars and see if they have some available.
Old Jan 19, 2007 | 11:16 AM
  #170
ArtemisKneptune
Thanks for the help!
