When do you need alignment?
Old Apr 2, 2004 | 07:46 AM
honda1998civic's Avatar
honda1998civic
Default When do you need alignment?
Hi,
Just wondering if alignments should be done on certain mileage or only if your car pulls to one side? Please post comments
Old Apr 2, 2004 | 07:55 AM
john666's Avatar
john666
Drive it like u stole it.
Probably best when your car isnt going str8 to get a alignment.. if you dont do it around that time.. you will notice that you have to change your tires or rotate your tires constantly..
Old Apr 2, 2004 | 09:25 AM
Running925's Avatar
Running925
Your Powder Coater
or if you change your ride height!
Old Apr 2, 2004 | 01:31 PM
Guzznuts's Avatar
Guzznuts
you'll be able to tell when you need an alignment by looking at your tires. if you get uneven wear on either the outside or inside shoulder, that's a tell tale sign that it's time to take it in for an alignment. another sign is when your tires are cupping or feathering. in that case, you're probably gonna have a problem wit your shocks or struts also.
Old Apr 3, 2004 | 07:11 PM
honda1998civic
oh... ok.. thanks guys.
Old Apr 3, 2004 | 07:41 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Your car can be aligned and still pull to one direction
This is the best way to check.
Old Apr 4, 2004 | 12:56 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Actually I recommend once a year. Even if the car is going straight or not pulling to one side. I actually get an alignment 3-4 times a year since I autocross so much and it puts a strain on the suspension. PLUS I raise and lower the car for winter/summer.
Autocross Help Page
Old Apr 4, 2004 | 06:51 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I get an allignment:
once at the beginning of summer (for autox season)
once at the end of summer (for winter driving--raised hight)
whenever I do any suspension work, since that tends to screw up your allignment.
Checking tire wear isn't big for me because my tires wear wierd anyway ( I run 2.5- camber f/ 1.5r in the summer), plus I do susp. work often enough that I get allingments faster than the tires wear. For a normal car though, checking tire wear is the best indicator.
Old Apr 4, 2004 | 09:00 PM
menappi's Avatar
menappi
on hondas i believe the only thing that can be corrected with an alignment is toe. i just got mine and my camber is messed up and caster too, but caster cant be fixed on my civic. camber can with a camber kit, and the toe can be fixed with the alignment. toe in or out will cause rapid tire wear and will produce bump steering, where ur steering wheel jerks when going over bumps. if your steering is all over the road, then you should get an alignment.
Old Apr 5, 2004 | 12:49 PM
Wharbone's Avatar
Wharbone
What alignment places offer lifetime alignment plans?
Ochdx
92+ Civic/EL & Del Sol
13
Mar 8, 2004 06:44 PM
5thgenAccordEX
Accord
12
Feb 7, 2004 01:47 PM
stephan
Track & Autocross
7
Oct 6, 2003 11:52 AM
Ochdx
4
Apr 18, 2003 12:40 PM
Accord1278
Accord
2
Nov 17, 2002 04:01 PM
