Shmoo's GSR Engine Build: Operation 400whp not 56k friendly
Old Oct 22, 2007 | 03:17 PM
  #151
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by Spec R
personal issues? penis enlargement is the answer! jk
hope everything works out, good luck!
Yeah, that wouldn't help me one bit.
Thanks for the support.
Originally Posted by ADRONICUS
So what do you get around in, in the meantime?
I'm driving it.
Old Oct 22, 2007 | 07:25 PM
  #152
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I'm driving it.
So is it back to normal? or are you just babying it?
Old Oct 22, 2007 | 09:13 PM
  #153
Provocateur
On permanent hiatus
I'm taking it easy. I won't go past half throttle or 6000 rpm. It is very drivable, though and it still moves without having to wind it out or mash the pedal.
Old Nov 12, 2007 | 06:53 PM
  #154
Provocateur
On permanent hiatus
~~Update~~
I have made absolutely no progress on the engine build. I am still working out the kinks of the turbo stuff.
Here is some progress I have made since last update:
-I welded the dumptube to fit properly, so now it is connected and dumping under the car instead of right on the radiator.
-I purchased a new oil pan and tapped it differently to remove the nasty kink in the return line. I am still not satisfied with the way the return line sits because the turbo is so damn low but I have to work with what I've got.
-I'm about 75% done tuning it. The only stuff I have left to tune are the vtec maps and the boost portion of the maps above 5 psi. I wish PWM boost was available for Neptune already so I could hook up a boost solenoid and tune for boost by gear and maybe crank it up to 8-9 psi to see about 310-320 whp. It has an 8 psi spring but with the altitude, I am only seeing about 6 psi of absolute pressure.
I have decided that I am going to go ahead and have the block sleeved. I can't decide on a 83 or 84mm bore, though. Any input?
Here is an updated picture of the turbo setup w/ new dumptube:
Old Nov 12, 2007 | 09:12 PM
  #155
Spec R's Avatar
Spec R
wow that looks crazy.
glad to see there's some progress.
as for the block sleeving, keep the smaller bore. more torque at this point just means more wheelspin in my opinion.
but what do i know.
another random question, did you have a problem with melting the rubber on your dipsticks with the greddy manifold?
DB Squad
Integra Forum Moderator
Old Nov 13, 2007 | 04:02 AM
  #156
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I would go with the 83mm bore, it will give u more expanision room.
Old Nov 13, 2007 | 07:00 AM
  #157
Provocateur
On permanent hiatus
Thanks for the input guys. I was leaning more toward 83mm as well just so there could be more meat on the sleeves in case something catastrophic happened and the block needed reboring. The torque issue is pretty much negligible between the two bore sizes since the difference in displacement is 1.88L vs 1.92L.
And yes, the Greddy manifold loved to melt the dipsticks since it was practically touching the dipstick tube. That manifold got so much hotter and stayed hotter much longer than the tubular piece. I don't think I have to worry about melting dipsticks any longer.
Oh and I tried rerouting the charge piping to have the compressor outlet to face down and run a 90 off it but the piping hangs lower than the oil pan, so I am stuck with the mess of bends I have now.
Old Nov 13, 2007 | 10:27 AM
  #158
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Nice, I see you went the the motorcycle filter?
Old Nov 13, 2007 | 10:30 AM
  #159
Provocateur
On permanent hiatus
No, just a random 2.75" inlet cone filter I found at work that we used to use for our old turbo kits. We sell it for $30 but with my hefty discount, I paid $6 for it.
Old Jan 2, 2008 | 06:15 PM
  #160
sherwood's Avatar
sherwood
I missed Sean
I find it hard to believe this has been sitting idle for 2 months h:
