Shmoo's GSR Engine Build: Operation 400whp not 56k friendly
Old Oct 9, 2007 | 09:49 PM
  #131
jesusublime99's Avatar
jesusublime99
Damn that sounds mean! Awesome startup video. Excellent job. :goodjob:
Old Oct 10, 2007 | 06:16 AM
  #132
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Sounds pretty aggressive. Make sure you shoot another video when that thing hits both the street and the dyno.
Old Oct 10, 2007 | 10:04 AM
  #133
Spec R's Avatar
Spec R
i love how you can hear the spool down.
congrats sir.
ps, your valve cover grounds arent grounded where u mounted them.
DB Squad
Integra Forum Moderator
Old Oct 10, 2007 | 10:11 AM
  #134
Provocateur's Avatar
Provocateur
On permanent hiatus
I will. I need to get tune it first, though. I haven't even boosted it yet.
congrats sir.
Yeah, the spool down is sick. Sounds like a turbo diesel.
They are grounded. There is no powdercoat underneath, just bare metal.
Old Oct 10, 2007 | 10:34 AM
  #135
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
where did u get the charge pipe that comes off the turbo? It looks like a casted piece. Did u front mount your cooling fan, or did you not put it on yet? sounds good.
Old Oct 10, 2007 | 10:47 AM
  #136
Spec R's Avatar
Spec R
yeah, think about it though, theres nothing grounded on the valve cover side. you got the valve cover gasket, the spark plug grommets, the rubber isoloated valve cover bolts, etc.
i made the same mistake.
the hole u used is for the RHD cars with the throttle cable that goes over the top of the valve cover.
use the bolt that was originally used with the car stock. that will have continuity through the head and the block.
DB Squad
Old Oct 10, 2007 | 10:50 AM
  #137
Spec R's Avatar
Spec R
not a DC chassis, but u get the idea
DB Squad
Old Oct 10, 2007 | 11:03 AM
  #138
Provocateur
On permanent hiatus
I got it from work. It was a tubular steel powdercoated (looked more like wrinkle paint to me) intercooler piece from Corky Bell's old Miata turbo kits that I cut to the angle I needed and had my room mate weld it and sand it down. I gave it some heavy coats of high temp aluminum paint to match the other charge pipes.
Ever since I removed my A/C a while back, I have been using pusher slim fans. Any puller mounted fan would probably cause clearance issues with either the charge piping or dumptube.
Good looking out. I didn't really think about it. I'll move it to the grommet where it originally was.
Old Oct 10, 2007 | 11:05 AM
  #139
Omniscient's Avatar
Omniscient
warm butter on toast
Sick shmoo. I welded up my own exhaust just like yours without the resonator or bullet muffler. I can still imagine it's loud as hell. But it's nice knowing there's other people crazy enough out there to run something like this.
Old Oct 12, 2007 | 10:28 AM
  #140
5 Lug's Avatar
5 Lug
Wow schmoo, looking good man. I may have missed it but any thoughts on going Hondata with engine management? It runs my 880 Precisions at like 900-1000 idle, they feel good. I'm running two SPAL fans, the pusher is on the front driver side and the puller is on the back passenger side. I can snap a picture if you wanted to see clearance. SC61, but the Inline Pro manifold could be the difference, but it's running AC. Anyway, keep it up.
