Shmoo's GSR Engine Build: Operation 400whp not 56k friendly
On permanent hiatus
I also took that gay looking purple line and I am going to route it behind the block in a black hose and ziptie it to the feed line and other vacuum hose to make it cleaner. The purple one just looked goofy and rerouting it will cause the line to be at least a foot shorter, which will be better for boost response.
For sure. I will have to figure out how to use my parent's digital video camera but I will do my best to have a video of what I did and what it sounds like.
On permanent hiatus
I was planning on taking it into work and piecing together some piping out of old turbo shit we have lying around. If I can pipe it upwards, I would love to stick a low profile "cone" filter behind the headlight. This way I will be getting cool air from the headlight instead of hot air from the radiator and it will place the filter higher up, so ingesting foreign objects and water will be much more difficult.
They make motorcycle filters with 2.75" inlets?
I know somebody who rides bikes regularly and at the track, I'll ask.
On permanent hiatus
It runs. It fired up first try with the new injectors and Neptune basemap. :yay:
With the open downpipe, it sounds and smells like an old muscle car. I made a video but I am retarded when it comes to video cameras, so I need to figure out how to get it from the camera onto the computer.
I found this for you. Check out all the filters w/2.75 inlets. I'm sure one has to fit.
http://www.knfilters.com/search/prod...x?Prod=SN-2600
It is just an example. I saw a shitload they may fit your app.
On permanent hiatus
Without further adieu...here is the startup video:
http://s53.photobucket.com/albums/g7...t=MVI_0105.flv
