Tax $$$$$$$ = ?????
Originally Posted by rugsr
u guys think that flywheel is better then an ITR?
called the dealership and they said 296 for a type r flywheel? also, they said it weighs 15lbs......i thought type r flywheels are 12
i might just buy this one http://www.mach1car.com/Product.aspx?nav=4&p=ACT600110
OH when buying the ACT-XTSS....do i have to say hydro,cable, etc? or does that have nothing to do with it
BTW, 95 GSRs are cable correct
GC and Koni are a much better value and outperform the Tein kit. Make sure you know what spring rate you want to run before you order it.
That flywheel should be just fine. There is a difference between cable and hydraulic clutches, so make sure you specify that you want one for a hydraulic transmission.
OH we have hydro tranys? didnt know this.
so the GC and konis are better then tein.......then i go with GC/konis
NOW when we are talking spring rate what does this mean? we talking stiffness or drop. cuz they way i see it is drop=coilover and stiffness=shock
sooooo whats the spring rate do?
