Tax $$$$$$$ = ?????
Old Mar 9, 2006 | 02:07 PM
FooD2000's Avatar
FooD2000
Still Water
Koni Adjustable yellows + spring kit:
http://www.importhorizon.com/konisportkit.html
Old Mar 9, 2006 | 02:21 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You don't want those crappy springs. Get Ground Controls if you are serious about your suspension.
Old Mar 9, 2006 | 02:34 PM
Driverman5777's Avatar
Driverman5777
^ which springs are crappy? The Konies?
Old Mar 9, 2006 | 03:19 PM
Provocateur
On permanent hiatus
Yeah. I don't think Koni makes them.
Old Mar 9, 2006 | 08:20 PM
rugsr's Avatar
rugsr
How do my taillights look
what lb flywheel would be good? make?
Ground Controls are better then Tein's?
ever heard of a LUK Gold clutch?
Old Mar 9, 2006 | 08:24 PM
Provocateur
On permanent hiatus
If I were to do it again, I would stick to a stock or Type R flywheel. 12 lbs is probably the lightest you should go with your future setup.
Teins are decent for street, but the spring rates are soft and the shocks are only 8 way adjustable. The Koni Yellow/GC setup can offer a custom spring rate and are 32 way adjustable for $500 less than the Tein Flex setup.
Old Mar 9, 2006 | 08:30 PM
Driverman5777
what about koni's and eibach pro?
Old Mar 9, 2006 | 08:34 PM
rugsr's Avatar
rugsr
so your saying get a type r flywheel? thats an idea! http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem
the teins are 16way i believe but still 32 is better espically for 500 less.
would this be them http://cgi.ebay.com/ebaymotors/KONI-...QQcmdZViewItem
wouldnt i need springs though?
Old Mar 9, 2006 | 08:38 PM
Provocateur
On permanent hiatus
http://www.honda-tech.com/zerothread?id=1355904
You should really buy that instead of looking on ebay. Make sure you have a custom spring rate in mind.
Old Mar 9, 2006 | 08:55 PM
rugsr's Avatar
rugsr
how do u guys feel about this
http://www.honda-tech.com/zerothread?id=1503237
better then ACT HDSS clutch?
BTW all ive been seeing is an organic clutch with 214ish TQ.....sounds like thats too low. isnt there anything better by ACT, like kevlar?
