**Brakes thread**
Old Mar 21, 2004 | 11:24 AM
  #31
joebenz's Avatar
joebenz
nelson rules
Originally Posted by WiLL
well, i thought i would be decided on a pad after this....but i guess i was wrong.
i just emailed cobalt to see if they can offer some insight. thanks for all the suggestions.
eddie was tellin me about axxis metal masters. so i think that's what i'm gonna buy. just gotta find them now
no sig
Old Mar 21, 2004 | 03:28 PM
  #32
Taiwanze7's Avatar
Taiwanze7
try http://www.speedbleeder.com/ ... prolly the best bang for the buck if you do brakes yourself.
Old Mar 22, 2004 | 11:21 AM
  #33
slickboy's Avatar
slickboy
ECHC junkee
Rotors: Brembo blanks(front..got em cheap). OE's in the back
Pads: Axxis Metal Masters all around(got em cheap also)
Fluids: Valvoline brake fluid
The Metal Masters are awesome pads. Stock pads worked a little better at low temps(cold temps outside or when driving at first in the morning). ALso, the MM's grind just a little at cold temps, but not when they get hotter. When the pads/rotors start to heat up some, they bite considerably harder than stock. No fade at all with them..braking feels more solid. Overall, I would definately go with these pads again.
Old Mar 22, 2004 | 11:23 AM
  #34
Asahi's Avatar
Asahi
Administrator
Better yet get a silicon hose and a small coke bottle. No check valve to fail like speed bleeders and less messy. ANd still fully do it yourself.
Old Mar 22, 2004 | 11:25 AM
  #35
Asahi's Avatar
Asahi
Administrator
Metal masters are junk. it is a considerable step down from an Axxis Ultimate which stil isn't in the same ball park as the others we continue to mention.
If I had to pick 2 pads I have seen mentioned in this whoel thread I have used and would not put on my worst enemies car it woudl be EBC Greens and Axiss Metal Masters. At the very least use Ultimates. But as mentioned, better yet use Cobalt GT Sports or Hawk HP+'s.
Old Mar 25, 2004 | 04:58 PM
  #36
redtide's Avatar
redtide
i have a question about brembo blanks. on some web sites is see "solid" and "vented" rotors. which ones are everyone calling the blanks?
Old Mar 25, 2004 | 05:15 PM
  #37
b00gers's Avatar
b00gers
the "blanks" are the OEM replacements. they are "solid", no vents.
Old Mar 25, 2004 | 07:06 PM
  #38
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
"Blank" rotors can be solid or vented, depending on application. Observe.
The rotor on the left is a vented rotor. It has vents between its two friction surfaces for cooling. The rotor on the right is a solid rotor. It has no vents.
On Integras (and most cars for that matter) the front rotors are vented and the rears are solid.
Old Mar 26, 2004 | 05:23 AM
  #39
redtide's Avatar
redtide
thanks for the help. that clears up my confusion.
Old Mar 26, 2004 | 07:47 AM
  #40
b00gers's Avatar
b00gers
:doh: ok thats what was meant by "vented." i thought it was the whole solid / drilled / slotted ordeal.
the brembos i have are vented.
