ABS Light On
Old Feb 8, 2004 | 03:36 PM
dawrenn's Avatar
dawrenn
Default ABS Light On
My brother recently got in an accident with his 97 Integra GSR. His left front wheel got hit while it was turned. now when the car is on the ABS light is on. What do you think the problem could be?
Also the windshield washer does not work, It does not even make a sound. It used to make a sound when it was out of water but I don't even hear that now. We checked the fuse and the the connection and everything seemed fine. Why do you think it is not working?
Old Feb 8, 2004 | 04:49 PM
timmy8151's Avatar
timmy8151
Could be a damaged ABS wheel sensor. However, the first thing you should do is pull the ABS code. To do this, you are going to have to find the green colored service connector. Its located by the kick panels on the passenger side. Once you find the connctor, you have to jump the connector. The easiest way to do this is by using a paperclip. Once the connector is jumped, you should see some flashes from the ABS light. A long flash=10 while a short flash=1, count the flashes and then get the ABS error code.
Old Feb 8, 2004 | 05:07 PM
stockhonda's Avatar
stockhonda
Sometimes the ABS light will appear in a flashing manner, just like the "CHECK ENGINE" light or Malfunction Indication Lamp (MIL). Much like the ECM, it's possible to check the code for problems with the ABS system.
For starters, locate the factory diagnostic plug next to the ECU for the Integra and Civic. It is located under the dashboard, to the right of the glove box. There is a two-pin connector that contains a brown and black wire.
Jump these two wires together and turn your key to the ON position.
Here is where it gets tricky. Deciphering the DTC (diagnostic trouble code) requires reading the light sequences. When the car is in the ON position, the ABS light emits two different flashes; a long extended flash means 10, and a rapid flash means 1. So, one long flash, another long flash, followed by 3 quick flash stands for...................23! Equipped with that information, here are the codes for '98-'01 models
DTC Location Symptom
11 FR Wheel sensor (open/short to body ground/short to power)
13 FL
15 RR
17 RL
12 FR Wheel Sensor (electrical noise/intermittent interruption)
14 FL
16 RR
18 RL
21 FR Pulser
22 FL
23 RR
24 RL
31 FR-IN Solenoid (short to body ground/short to wire)
32 FR-OUT
33 FL-IN
34 FL-OUT
35 RR-IN
36 RR-OUT
37 RL-IN
38 RL-OUT
41 FR Wheel Lock
42 FL
43 RR
44 RL
51 Wheel Lock
52 Motor Stuck OFF
53 Motor Stuck ON
54 Fail-safe Relay
61 Ignition Voltage
62
71 Different Diameter Tire
81 Central Processing Unit (CPU)
All of that, taken directly from here, courtesy of Gvtec from Team-Integra.net
As for the windshield washer sprayer;
are you sure it has fluid in it? you just might not be able to hear the pump.
The nozzles could be frozen, it has been very cold lately, park it in a garage, and see if it thaws out.
Old Feb 9, 2004 | 02:54 AM
dawrenn's Avatar
dawrenn
I am sure it has fluid in it, that is the first thing I did was put fluid in it. I used to always hear the pump. The nozzles are not frozen b/c it has not been cold here.
There was no damage to the bottle or any of the connectors. I don't know what the problem is.
I hope I will be able to figure out why the abs sensor is on and whe the windshield washers do not work b/c I am definitnly not going to take it to an Acura dealer, they will tell you to bend over when you wak in. I guess if I can't figure out the problem my brother will have to deal with the ABS light being on and non-working windshield washers.
Old Feb 9, 2004 | 03:31 PM
dawrenn's Avatar
dawrenn
To The Top
Old Feb 9, 2004 | 07:10 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Check the code using the method posted above and you will at least have a starting point with diagnosing the problem.
Old Feb 10, 2004 | 02:28 AM
SkunkedIntegra's Avatar
SkunkedIntegra
I am having the same problem with the abs light. Just wondering, about how much does a wheel sensor run?
Old Feb 10, 2004 | 10:07 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I had to replace one of my wheel sensors, I think it ran about $150 for the part.
Old Mar 2, 2004 | 09:00 AM
dawrenn's Avatar
dawrenn
I got 2 of the for $25
tim
Accord
12
Aug 12, 2003 10:42 AM
honda_forever
Accord
9
Feb 5, 2003 08:24 AM
Ziggityz83
Accord
2
Dec 10, 2002 04:13 PM
Vegeeta
Accord
5
Aug 29, 2002 09:03 AM
ElectronBlueGSR
92+ Civic/EL & Del Sol
12
Jun 21, 2002 07:58 AM
