ABS light
Old Dec 9, 2002 | 07:12 PM
Ziggityz83's Avatar
Ziggityz83
Default ABS light
Ever since I have had my car (95 accord) (Feb. 2002) the ABS light has been on..the guy i bought it from said that he had the breaks serviced..which he did, the papers were in the glove box. My friend has an integra and he said that under the steering column there is a box that he could press a button to reset the dash and the light would go off..I was wondering if the same is true for accords..if so let me know.
Old Dec 10, 2002 | 12:57 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
there is no button that I am aware of... when the ABS light comes on, it means there is a fault in the system and the ABS is not functioning. Usually in the accords, if the ABS light comes on, it is due to a faulty wheel sensor. Autozone, I believe, can diagnose the car for free and tell you which sensor is bad. The sensors are only available as a Honda part... no aftermarket ones available.
To reset the light, the problem has to be fixed.
Old Dec 10, 2002 | 04:13 PM
KMFDM's Avatar
KMFDM
check the fuses in the abs box
