grinding???
Old Jun 22, 2003 | 04:27 PM
preylude99's Avatar
preylude99
Default grinding???
hey what is all this I hear about the rsx type-s having problems with 2nd gear and 3rd gear grinding? If you read on clubrsx.com there are a lot of people who have the problem, however they shift... I was considering getting an S but that is kind of swaying me away, I know the dealer would/should cover it, but it would not only be an inconvenience to have it done, but people on clubrsx.com have had it done and it still started happening in a few weeks again. What is your guys' take on this? Did honda/acura screw up on the new designed syncros for the type-s?
Old Jun 23, 2003 | 06:46 AM
hertzy's Avatar
hertzy
yeah they did screw it up.......and even on the newer models (i have an 03 type s) and it's still messed up. Mine only happens at redline which isn't so bad but some guys have hard grinds throughout the rev range.
I'd still recommend the s...the performance and style are great and it responds really well to mods. And, hopefully with a quick fix i.e. short shifter the grind should cease. It's all up to you though. Oh...btw...most of thiese grind problems seems to diminish once you put dome miles on the car it's only a few (like me) who have it persist.
Old Jun 23, 2003 | 08:40 AM
preylude99's Avatar
preylude99
oh I know, I love the car, and the even though it may have problems of grinding it still may not be enough to sway me away from it. But the point is, why pay over 20K for a car that grinds and that most dealers do not want to do anything about, I was dissapointed in honda/acura when I heard this.....It wasnt about the problem, it was mostly that they didnt want to do anything about it in most cases....
Old Jun 23, 2003 | 09:30 AM
hertzy's Avatar
hertzy
there is a tsb released for it.......so you shouldn't have any dealer probs. but do your research at a dealer and get it addressed by them b4 you buy
Old Jul 9, 2003 | 05:43 PM
Ross's Avatar
Ross
i have the same prob. shifting into 5th gear in my 2000 SI and it just started doing it at 40000 miles
Old Jul 9, 2003 | 09:59 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
there should be a sticky grinding post.... All in favor say "I"
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Jul 10, 2003 | 04:00 AM
Ross's Avatar
Ross
sounds good
Old Jul 11, 2003 | 01:49 PM
blackandred's Avatar
blackandred
I
Old Jul 12, 2003 | 01:36 PM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
ugh..........nay
Old Jul 13, 2003 | 02:00 AM
NSBTypeS's Avatar
NSBTypeS
MMM MMM Bitch
gomt mine repaired under warranty w/ no problems. Just take it in and say it pops out of gear sometimes, nothin major, just like 5 times in the last month, and " can u check it out " the tech will then drive your car, not find anything wrong but just to be sure acura will tear apart your tranny and WILL find ****ed up gears that they will have to replace b/c you dont race or drive hard :naughty: , at all!!! :naughty: You can also replace some parts in the drivetrain w/ aftermarket shit, as I did.
