engine overheats with turbo going uphill
Old Jun 24, 2002 | 12:25 AM
accordfreak's Avatar
accordfreak
Default engine overheats with turbo going uphill
a new turbo has just been installed on my stock engine... the a/c lines were bent ... the filter pipe of the turbo is touching the radiator hose, the stock oil cooler was removed and the fan was tapped into for it to turn on after the car shuts off... this is a 94 accord ex
when i drive uphill the temp needles goes to half and when i'm back on flat surface it goes back to normal... would it be a time to upgrade to a new radiator and a new oil cooler??? would that solve my over heating problem?? right now I'm using 5w30 synthetic oil ...so would 10w40 help my overheating??
Old Jun 24, 2002 | 02:29 AM
jaje's Avatar
jaje
HC Racer H5
what turbo kit is avail for the f22b1?
Old Jun 24, 2002 | 06:06 PM
Eddiebx's Avatar
Eddiebx
Hmm.....where's the stock oil cooler your talking about? That's cool, I never saw one on the F22s, I know there's an oil cooler for the H22s though, its like on the filter base. But maybe you need a bigger radiator. Like a fluidyne or something, and it might not hurt to run a bit thicker oil like 10w30 probably will withstand the turbo better. I remember one of my friends that turboed his lude, used 10w50 I think. I would try that first, them maybe get an aftermarket oil cooler installed if that stuff fails.
Just wondering is yours an auto or 5spd? That turbo would probably be hell on the tranny if you have an auto, hehe.
Eddie
Old Jun 25, 2002 | 08:21 AM
Ben95ex's Avatar
Ben95ex
unless you live somewhere where the temperature drops below freezing on a regular basis, or you're running a brand new engine, 5w30 is too thin. 10w40 or 15w50 is probably a better choice, especially with a turbo... synthetic of course.
i didn't think 5th gens came with oil coolers... i own one and i've never seen one on my car.
Old Jun 25, 2002 | 08:29 AM
Ben95ex's Avatar
Ben95ex
F-Max and Drag make kits readily available in the U.S.
HKS and GReddy (Trust) make kits for the F22/F23
check out www.takakaira.com
Old Jun 28, 2002 | 11:17 AM
AP2's Avatar
AP2
Moderator Alumni
Try to get that filter pipe not to touch the upper coolant hose. As innocent as it looks, that pipe can get hot enough to make a difference in coolant temps.
Old Jul 4, 2002 | 05:48 PM
accordfreak
thanks for your replies... i finally figured it out that it was air bubbles in my coolant... perfectly normal now...geez..
Old Jul 4, 2002 | 08:10 PM
Aeka GSR's Avatar
Aeka GSR
Are you constantly boosting while going uphill. holding a boost uphill = bad.
Old Jul 4, 2002 | 08:45 PM
accordfreak
nope... on those hills i push the gas almost an inch down... i try to not boost at all on hills
angelgabe
5
Jul 10, 2006 10:11 AM
ABTsportsline
Engine Swaps, Tech & Tuning
2
May 24, 2005 01:06 AM
IInteg4Trade
Prelude
2
Sep 10, 2004 04:38 PM
wijiwang
3
Jun 28, 2004 12:04 PM
Sunny
Accord
17
Apr 19, 2004 12:15 PM
