Post Questions about engine swaps.
Old Nov 3, 2002 | 06:17 AM
  #51
Guest
Guest
Posts: n/a
can you give me a parts list....for a zc into a 89 STD hatch please!? thanks! price ranges included
Old Nov 6, 2002 | 03:18 AM
  #52
wraithsgsr's Avatar
wraithsgsr
Whats the better engine mount kit, The HASport or the HCP Engineering for dropping a B18C5 into a CRX?
Old Nov 20, 2002 | 07:48 AM
  #53
Creep's Avatar
Creep
Originally posted by noVTEC
doing it myself! so how much u think all that **** will cost?
Will all d series motors bolt into my EF?
Old Nov 20, 2002 | 01:26 PM
  #54
slomo's Avatar
slomo
i believe any d series engine from 91 or older will bolt right in. I'm unsure of the newer d series motors..
Old Nov 30, 2002 | 05:18 PM
  #55
red.da's Avatar
red.da
how hard and what is all needed to get a 88-89 teg engine into an 87 style rex? i know you have to convert to mpfi, use the teg ecu, most likely integra axles/transmission? anything else major like mounts, shift linkage?
thanks
Old Dec 17, 2002 | 07:15 PM
  #56
SuperSlow87's Avatar
SuperSlow87
H-A G/\|v|3R
Will d-series integra engines swap into a 1st Gen CRX? Who sells mount kits? I checked with HASport and then only sell b16 mount kits for the 84-87 CRX
Old Dec 18, 2002 | 07:31 PM
  #57
Knightmare69's Avatar
Knightmare69
Hater
What do I need to swap a Ls engine into a 91 Civic Dx and what year Ls should I look for. Also, Ls is the best engine to boost correct? Should I also take the manual tranny since the Dx is being converted from auto to manual and are there any write-ups on these swaps?
Old Jan 2, 2003 | 12:14 AM
  #58
Kai's Avatar
Kai
Rotorphile.
Is it possible to adapt a D15A3 or D16A1 vacuum advance distributor to any modern electronic distributor 16 valve (D16A6, Z6, Y8 etc) SOHC head?
Old Jan 13, 2003 | 01:05 PM
  #59
Knightmare69
Hater
Will a B16A I think from a CTR fit into a 91 Civic DX and what tranny would be ideal for this swap? Also, is the LS engine swap common and who on the East Coast near New York/CT can do these swaps?
Old Jan 15, 2003 | 12:40 PM
  #60
RiceBoysDream's Avatar
RiceBoysDream
ok, what tranny can i use when i go with my b18a in my rex, i have an si, can i still use my si cable tranny? the motor im getting has no tranny or intake manifold, its just the pure engine. also what do i have to do when it comes to wiring? can i keep my si ecu or will i have to use the ls ecu?
