Swap problems
Everyone seems to talk about a breaker bar... but what exactly does a breaker bar look like??
I got a hold of an impact wrench, but the nut on the axles still didnt want to budge
In terms of what it looks like, its just a bar... could be a shower curtain rod, a chin-up bar, or whatever relatively strong piping you can find that will fit over the end of your wrench.
Originally Posted by monicle
That makes very little sense. Hes still going to need to get the pin out after he pulls the engine so why waste a perfectly good shift linkage.
The bitch pin, or "spring pin" should ideally be removed with an 8mm pin punch. I couldn't find an 8mm pin punch, at Sears, I bought some SAE pin punches.
A pin punch will have a rounded bump on the business end of the punch, that centers the punch into the pin.
Here is the trick. Once you get it centered on the pin. Hammer it from the top
I connected all my 3/8 extensions together (a 12in, and 2 2in.) And just hammered it out from the top. It goes much smoother when you can fully swing the hammer.
This is the replacment part I'm using on my stock D16Y8 : http://www.slhondaparts.com/search.a...=90751-s04-000
-PHiZ
I connected all my 3/8 extensions together (a 12in, and 2 2in.) And just hammered it out from the top. It goes much smoother when you can fully swing the hammer.This is the replacment part I'm using on my stock D16Y8 : http://www.slhondaparts.com/search.a...=90751-s04-000
-PHiZ
bboygraphix
Engine Swaps, Tech & Tuning
3
Jul 12, 2006 10:01 PM
