Help with dash panel "D4" light
Old Jun 5, 2007 | 07:32 PM
Misa's Avatar
Misa
Pic Whore
Originally Posted by humblehyper
Cool! Let me try it one more time, actually my brother-in-law was the one who took off the cluster, but we'll try again. Thanks!
its pretty easy
there are 2 screws on the top... near the plastic
remove those, and pull the black trim piece out... it is held on by clips.
then there are 4 screws that hold the cluster in place.
remove those, and the cluster should be able to come out.
If you disconnect the cluster harness, DO not start the car without plugging it back in.
Old Jun 5, 2007 | 07:45 PM
stereo's Avatar
stereo
after you pull the white plastic cover off the back (without breaking the clips) you will notice all the A/T bulbs are on the other side all the other bulbs are twist off and can be changed in the back without takeing it appart but the P R N D 2 1 bulbs are installed on the face side of the circut board and not the back PCB side , you don't have to pull the needles but the gauges have to be pulled off the board to get to the bulbs ...
Old Jun 5, 2007 | 07:53 PM
Misa's Avatar
Misa
Pic Whore
the PRND as well as the other 7 or whatever bulbs that light the needles , odo, and the face are all on the same side. I had to replace the ODO bulb... and from the shock of removing it... the d4 light went out.... i switched it with the d1 light and it worked.... and i didn't need to remove any cover or board off of the cluster.
do you want me to take a picture of it in the morning?
edit: he has a 2000. i hope your not thinking of the older gauges.
Old Jun 5, 2007 | 08:14 PM
humblehyper's Avatar
humblehyper
If you can take a picture please, I really appreciate it. Thanks so much.
Old Jun 5, 2007 | 09:46 PM
stereo's Avatar
stereo
if you look at the pic the bulb is #20 it's mounted in the front like on my 99 I will try and take a pic of it appart.
http://www.hondaautomotiveparts.com/...METER+%28NS%29
Old Jun 7, 2007 | 07:47 AM
humblehyper
How did you disassemble the cluster? Can you please take a picture showing what to take off, I'm such a newbie, I dont know much about cars, but I'm trying to learn Thanks so much for taking the time to take the picture, I really appreciate it.
Old Jun 7, 2007 | 09:00 AM
Misa's Avatar
Misa
Pic Whore
HOLY CRAP..... that looks nothing like my 98 :eek3:
Old Jun 7, 2007 | 09:23 AM
Misa's Avatar
Misa
Pic Whore
this is what i got.
Old Jun 7, 2007 | 11:48 AM
stereo's Avatar
stereo
basically you pull the back cover off, on each gauge you see 2 tabs retaining it bend them so the gauge comes out on the center of the baord you stt a tab it locks the board in just press on it and gently pull around the board loose until the gauges on the other side comes off. but it's a dangerous job as you can easly mess up the gauges, I repair gauges and mod them on my spare time so it's easy for me to do, then the bulb pulls off to reinstall I usally put all the gauges clear housing and all in press the board in gently almost all the way in then pull the front off with a clean cloth push it in until the retaining clips are all the way out.
Old Jun 7, 2007 | 11:50 AM
stereo's Avatar
stereo
the first year of every car or coupe will have a diffrent setup , I have 5 gauge sets here 99's a 2k's all are the same as the pic taken.
