Ask simple and basic questions part Tres..
Old Nov 12, 2003 | 10:37 PM
  #51
Nelson's Avatar
Nelson
Administrator
Originally posted by CivicSiRacer
Whatever the dealership tells you most mods do not void the warrenty of the car unless they can prove that the part somehow caused the problem.
Aka: you installed aftermarket springs BUT your engine blew up. There's no way the springs had any effect on your motor. But if you installed a cold air intake and you drove through a puddle which sucked up water and seized your engine then of course that would be your fault.
:werd:
Like CivicSi said, they have to prove whatever you did had a direct effect on what went wrong. I have a few friends with heavily modified cars bring their cars back for under warantee... (Tranny rebuild, Clutch replacement, ECU malfunction, etc)
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Nov 13, 2003 | 10:01 PM
  #52
Wharbone's Avatar
Wharbone
How hard is it to mod a oem front lip for the 5th gen coupes/hatches to fit a sedan? What all needs to be done?
Old Nov 14, 2003 | 10:15 AM
  #53
ikarus's Avatar
ikarus
ty CivicSiRacer & MaxBoosT for the info so no matter what they say about putting on aftermarket parts its BS then i guess as long as that part is not the direct cause of the problem and they can prove it. So i should be fine installing and intake and exhaust then . Another question though do i get intake and exhaust done by Honda or should i take it to a speed shop. Do u know of any good speed shops in the area of NYC/LI/Westchester Co.?
Old Nov 14, 2003 | 03:50 PM
  #54
Snoopy's Avatar
Snoopy
been there done that
try and do it yourself. intake and exhaust arent very difficult if you have basic hand tools.
Old Nov 14, 2003 | 05:14 PM
  #55
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
For the typical newbie the exhaust will take about 1 hour with simple hand tools. Just make sure you spray all the bolts with WD-40 or Penetrating spray if the car is old.
Intake should take you about the same.
Autocross Help Page
Old Nov 14, 2003 | 10:13 PM
  #56
zeroseven's Avatar
zeroseven
Ok, i took off my wiper arms on my ek civic so i could repaint them and now i dont remember how to put em back on. Does the longer arm go on the driver or passenger side? Also the shorter wiper blade goes on the longer arm right? And where should they rest when i put them back on along the window. Oh, and yes i know i am stupid h:
:edit i got it all worked out nevermind. h:
Old Nov 17, 2003 | 02:29 PM
  #57
ricereaper's Avatar
ricereaper
i need some info on hooker headers for my civic ex---or what kind of j-spec engines will fit without blowin up the car. will a 150 shot of nitrous oxide do much for me?
Old Nov 17, 2003 | 06:07 PM
  #58
Snoopy's Avatar
Snoopy
yes a 150 shot will rocket you to the moon. hopefully you'll run out of gas and not make it back. :wiggle:
Old Nov 18, 2003 | 11:50 AM
  #59
ricereaper's Avatar
ricereaper
yeah then i don't have to listen to your crap.....:fawk:
Old Nov 18, 2003 | 06:52 PM
  #60
Snoopy's Avatar
Snoopy
go now....
