Ask simple and basic questions part Tres..
Old Aug 20, 2003 | 05:16 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
Default Ask simple and basic questions part Tres..
Unstuck the other thread felt it was getting too long. So if you have some questions just post in here, and we'll try to get 'em answered.
The old thread is still around, you'll just have to search for it.
I've got a question myself. Rear wheel bearings, anyone replace 'em? I think I need to do mine, looking for some input.
Also. Main relay for the fuel pump, where is it under the dash exactly?
Project EVA - The Track Package
Project EVA
Old Aug 20, 2003 | 09:11 AM
FocuzDave's Avatar
FocuzDave
Member with a mega dong
Blow-Off valves......can you have two of them if your car is bi-turbo? whats the dif between a blow off and a diverter....B o V's take the gasses out of the turbo and send them where? How come superchargers don't have blow off valves?
Old Aug 20, 2003 | 11:07 AM
Jessica's Avatar
Jessica
ch1x0r
Default Re: Ask simple and basic questions part Tres..
i'm doing my rear wheel bearings this weeked (well, not me, my friends). i heard its a major bitch to do.
Bumnah's Avatar
Bumnah
So OG it hurts.
Diverter valves are similar to BOV's. They discharge the air back into the system, instead of into the atmosphere like regular BOV's.
Diverter valves are what most stock cars have that come turbo'd from the factory.
I'm not usre why'd you want two blow off valves someone else my know. But you dont' need two blow off valves for 2 turbo setups.
Blow off valves discharge air from the charge pipe (from intercooler [if there is one] to the throttle body). Most of the time it's released into the atmosphere.
I believe super charged systems have blow off valves or diverter valves.
Project EVA
Old Aug 20, 2003 | 12:46 PM
FocuzDave's Avatar
FocuzDave
are the bov or diverters built in to the supercharger or is that a seperate peice you can buy? thanks :thumbup:
Old Aug 20, 2003 | 01:07 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
seperate. like i said. they go on the charge pipe.....
Project EVA
Old Aug 22, 2003 | 02:10 PM
mishima_beef's Avatar
mishima_beef
I have some question about sway bars...
is it the bigger the sway bar the better?
27mm front big? will it be ok a civic h/b?
Old Aug 22, 2003 | 04:03 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
That depends on which end of the car you are talking about. A larger front sway bar will make your car harder to turn (it will understeer more). A larger rear sway bar will make the car corner more neutral but can also make the car oversteer too. For the street you want a little bit of both to be able to dial in.
Autocross Help Page
Old Aug 22, 2003 | 11:05 PM
zacharyaus's Avatar
zacharyaus
I am interested in an Apexi V-AFC, what are the benefits of having a V-tec controller?
Old Aug 23, 2003 | 04:51 AM
CivicSiRacer
Really none if you have no other mods. But with the VTEC AFC you should take it to a dyno shop to get it tuned properly.
Autocross Help Page
