d16y7 = 200 hp?!?
people always ask why.....i say why not. if you've got the mad cash and time to pull it off then i say you're cool. it's not the route that i would take, but who the hell am i. i thinks it's cool to see cars with the mad underdog sized motors running good times. it's not always about the cheapest route for some people. i guess some just want to build a different motor.
HI welcome to the internet...
its this
NOT
thanks....
my bum is on the swedish!
Originally posted by Redcivic
18secferio, what shop was that? SA shops don't know shit.
But it is possible to get that kind of HP out of that engine but not without some cash. And a D16Z6 can handle 200HP reliably easy.
I know of a hatchback with a turbocharged DX motor running 12's. It has a lot of cash into the block and head though.
A shop in SA doing that kind of work though? None that I know of could do it. My cousin went to every shop in SA to see if they could install his cybernations Turbo Kit on his RSX and all of them declined to do it. He wanted someone else to do it to save time since it's his daily driver. We did it in two weeks working after work. It was relatively easy. I hate the shops here that is why I do everything myself except block work. But i know a guy that is a genious at building honda blocks but he does'nt own a shop so it takes him time to do the work.
Either way, someone is stupid.
Originally posted by oc_civic
thats the same thing a guy with a worked mustang could say to you.. "why waste your time with a honda.. you could go much faster in a mustang for less money"
my take on the whole thing..... i have a y8 which is an equally crappy motor just has vtec... and i have had a 60 shot on it for almost 2 years now with NO problem... so im pretty sure you could get 200 hp out of a y7 utilizing nitrous.. my friend jared (some of you may remember him his name was builthatch) had a built y7 with nitrous and was running a pretty big shot... my assumption is you have about a 100 hp stock at the motor.... between building it bolt ons and a large wet shot you could probably eaily see 200 hp at the motor.. and i always figure on about %15 loss to the wheelsso youd need like 230ish at the motor.. would it be easy OR cost effective.. no probably not.. but i think you COULD do it.. and once built it would IMHO not be that much more unreliable than any other built honda motor
Originally posted by 18secFerio
cost effectiveness is the key here. This kid's not rich. In fact, I'm better off than he is.
see thats where im at.. i want a swap.. who the hell doesn't.. but its cost for me and time per... i can buy parts for this motor.. build it up slowly over time still be driving it every day and spray and be reasonably fast... without the down time and ALL AT ONCE cost of a swap.
maybe I'm just annoyed by it because its the same powertrain as mine, but I think he's a fucking idiot.
all at once, or a little at a time, it still = $5000
you never mentioned it was an auto. the stock auto tranny from honda should never be handling more than 50hp over factory hp. anyhting over that is usually recommended to get a built tranny or swap to a 5 speed.
also,
im getting sick and tired of people saying "just swap it".
each to his own.
also,
each to his own.
Okay you tards, the Y7 is just like the Y8 except for the intake manfiold and VTEC head. Other than that, they're probably the same damn motor. I have approx 200whp on my car running 8psi of boost with the Greddy kit, FMIC, and exhaust. Now that I have fuel mods, there's no telling what I can lay down on the dyno. I've been running this setup for almost 2 years now with no problems.
I also know a guy who pushed 302whp and 256ft/lbs with a D16Y8 and stock internals. He just used an aftermarket head gasket. These motors are stronger than everyone thinks, so give the "do a swap" routine a break. You can spend $4k on a swap and I'll spend $2k on a turbo kit and own your ass.
