ARP head studs
Old Sep 18, 2006 | 04:42 PM
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by Däs Schmoo
No.
Torque them to 25 ft/lbs and then torque to 50 ft/lbs. One at a time, loosen 1/2 turn, then re-torque to 50 ft/lbs. Do this 3 times per stud and then do a final torque to 75 ft/lbs. Keep in mind, this is all done in the normal criss-cross fashion working your way out.
This is correct :thumbup:
don't forget to use your ARP lube on the threads of the studs b4 sticking them into the block. Torque the bastards to 25 / 50 / then 70 & call it a day!
Old Sep 18, 2006 | 06:04 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Ok, so I torque each one in the criss cross pattern to 25, then in the same pattern 50, loosen them in the same pattern 1/2 turn then torque all back to 50, then final torque at 70. Or is it 25, 50, 50, 50, 75? I'm sorry for being so literal about this, I'd just hate to finish the motor only to have a leaky headgasket or worse, a warped head.
Old Sep 18, 2006 | 07:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Almost.
You want to stretch them at 50 ft/lbs one at a time three times each done one at a time. So take that inside bolt that has been torqued to 50 ft/lbs, loosen 1/2 turn, retorque to 50 ft/lbs and repeat twice. After it has been torqued 3 times to 50 ft/lbs, move to the next bolt in crisscross fashion.
Old Sep 18, 2006 | 07:12 PM
ReVenGe's Avatar
ReVenGe
does it normaly come with the lube? or do i have to get that from pep boys etc.
Old Sep 18, 2006 | 07:43 PM
Running925's Avatar
Running925
Your Powder Coater
they normally come with the lube
Old Sep 18, 2006 | 09:38 PM
Omniscient's Avatar
Omniscient
My rod bolts that came with the rods came with lube and the head studs came with lube. So unless the seller is a cheap bastard it should come with plenty of the stuff.
Old Sep 18, 2006 | 09:41 PM
Omniscient's Avatar
Omniscient
Almost.
1. Crisscross pattern 25ft lb.
2. Crisscross pattern 50ft lb.
3. Loosen and retorque each bolt individually 3 times to 50ft lb and continue to do so in the crisscross pattern.
4. Torque all to 70ft lb.
Old Sep 19, 2006 | 01:00 AM
ReVenGe's Avatar
ReVenGe
i got that your suposed to just work on 1 at a time.... mix step 2 and 3 together... like put it in and work it, then go to the next?
Old Sep 19, 2006 | 05:11 AM
Running925's Avatar
Running925
Your Powder Coater
absolutly not, that would apply extream pressure to the head in one spot & not anywhere else.
Old Sep 19, 2006 | 11:38 AM
Provocateur
On permanent hiatus
When they are all torqued to 50 ft/lbs and it comes time to stretch the bolts, loosening each bolt 1/2 turn at a time and retorquing is the proper way to do it. You do want to initially and finally torque them in a criss-cross pattern, though.
