ARP head studs
Old Sep 15, 2006 | 10:06 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Default ARP head studs
These instructions are confusing me. They're for a B16a, the instructions say:
[A] Torque values are based on 75% of the fasteners yield strength. Use the manufacturers torque sequence but do not use the engine manufactureres torque specs. Torque the nuts to 70ft lbs.
[B] Due to the expansion rate of ALUMINUM, it is recommended that the torque should be 65ft lbs.
So which do I number do I go by 70ft lbs or 65ft lbs?
Old Sep 16, 2006 | 10:37 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
My Golden Eagle studs had to first be torqued to 25 ft/lbs, then stretched by loosening and tightening them one by one three times to 50 ft/lbs, and then a final torque value of 75 ft/lbs. I think the ARP are the same way, but I am not sure. 65 ft/lbs seems low since the OEM torque value is 60 ft/lbs.
Old Sep 16, 2006 | 11:10 AM
MTEng's Avatar
MTEng
I only see rod bolt torques on the ARP website.
You may do best contacting the manufacturer.
Old Sep 16, 2006 | 03:15 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
I torqued mine to 70 on my old B16.
Old Sep 17, 2006 | 10:34 PM
Omniscient's Avatar
Omniscient
I'm probably not going to get around to finishing until later in the week. I just don't want to fuck this one part up.
Old Sep 17, 2006 | 11:24 PM
ReVenGe's Avatar
ReVenGe
im glad you brought this up... mine are comin in the mail for my mini me swap... i wasnt sure either which torque to do... i just know that you re-torque them
Old Sep 18, 2006 | 01:29 PM
raiden571's Avatar
raiden571
turning u inside out
tony and me did the exact same thing with my motor and i havent had a problem yet. mmm. how i love driving it
Old Sep 18, 2006 | 01:35 PM
Omniscient's Avatar
Omniscient
So 25, loosen, 50, loosen, 75?
Old Sep 18, 2006 | 01:46 PM
Provocateur
On permanent hiatus
No.
Torque them to 25 ft/lbs and then torque to 50 ft/lbs. One at a time, loosen 1/2 turn, then re-torque to 50 ft/lbs. Do this 3 times per stud and then do a final torque to 75 ft/lbs. Keep in mind, this is all done in the normal criss-cross fashion working your way out.
Old Sep 18, 2006 | 04:19 PM
RedlineBoyzCRX
EG6
No.
The man knows what he is talking about.
