Possible Dumb Question
Old Oct 5, 2004 | 03:30 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
So, what jdm engine series would you recommend if i wanted to F/I??
Old Oct 5, 2004 | 03:34 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
well the BEST would probably be B18B non vtec.. they like forced induction..
Another *good* motor would probably be the B18C1...
check out westcoaststyle's car.. its turbo b18c1.. I worship it
Why are you so hell-bent on a JDM motor?
I guess it would be the B18C and B18B motors, respectively
Old Oct 5, 2004 | 07:26 PM
Kai's Avatar
Kai
Rotorphile.
JDM is not "all that" and the proverbial bag of chips... you can often find a good deal on a US engine.
For boost, it would be a toss-up between a B18B and a B18C.
If money was no issue, I'd go nuts with an H22A plus turbo.
Then again, if money was no issue, I'd pick a different car to work on. Honda motors are expensive... Supra, DSM, and RX-7 engines aren't.
Old Oct 5, 2004 | 08:05 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
the nice thing about type R engines is that if you want to go boost with it, you can sell the stock parts (pistons, rods, etc) on ebay for $$$
well, you'll get more than you would gsr parts :dunno:
Old Oct 5, 2004 | 08:26 PM
SamuraiBill's Avatar
SamuraiBill
H22 is where the speed is at. Alot more base horsepower (220) provided you get the right motor. I have a h22 civic and its bad ass with no mods. I am also the only one in my area,that I know of, that has one, and that is cool.
Austin
Old Oct 5, 2004 | 10:36 PM
qtiger's Avatar
qtiger
I easily have the money for any of the engines. My main part is performance and custom aspects for the engine. The type R comes with a higher BHP but do you know if it is more customizable or tunable then the other b18 series engines or would be the same?
If you're going to be upgrading the engine the ONLY drawbacks to getting a GSR engine instead of a Type R are: Intake manifold, and transmission. The GSR comes with a dual stage intake manifold which is almost universally thrown out the window by modders. The R comes with limited slip in the trans, as well as a tweaked final drive.
But seriously, if you're going to rebuild the engines at all, all the advantages of a R vanish. The R's cams make more power, but a piddly amount more... either way you'll replace them. Pistons have a higher dome, but not enough for aggressive cams. Rods slightly stronger, but not strong enough.
The fact of the matter is that the R engine, while a trick little number, is still just a tweaked street machine. If you're going for power it'll need just as much modification as the rest of the VTEC engines.
Old Oct 5, 2004 | 10:42 PM
Kai's Avatar
Kai
Rotorphile.
The intake manifold is a minor problem, thanks to the Skunk2 manifold and similar R copies made for the P72 bolt pattern.
The GS-R trans is also a minor inconvenience, as you can drop in a number of LSD's and change the final drive gear (ex: a JDM Type R 4.75) if you like.
Old Oct 5, 2004 | 10:47 PM
qtiger's Avatar
qtiger
Exactly. He asked if the R engines were less customizable. Those two problems are the only barriers to tuning in which the GSR costs more to modify than the R.
