Replaced distributor, car still wont start, HELP!
Old Sep 24, 2004 | 03:06 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
well by now the plugs could be fouled, replace them first before you look at the timing belt or ecu.
Old Sep 24, 2004 | 03:10 PM
Ochdx's Avatar
Ochdx
plugs are just over a year old and visually seem ok.
what is the easiest way to inspect the timing belt?
Old Sep 24, 2004 | 03:11 PM
NeverBX's Avatar
NeverBX
replace them anyway.
if it was your timing belt then the rotor wouldnt be spinning.
Old Sep 24, 2004 | 03:18 PM
Ochdx's Avatar
Ochdx
thanks for the info. just to get an understanding, could you briefly describe what happens when im turning the crank? what steps take place before the rotor turns?
Old Sep 24, 2004 | 03:23 PM
NeverBX's Avatar
NeverBX
when you turn the crank it rotates the belt and turns the cam and the cam turns the rotor.
Old Sep 24, 2004 | 03:34 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
sorry, I was responding to the other guy that posted... my bad.
fouled plugs?
have you checked your ignition timing?
Old Sep 24, 2004 | 04:46 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Heres an idea.....takes 2 people.
Since you have spark at the dist, pull your plugs put them back into the wires, touch to metal, and try starting. you'll see them spark if all is well. if not, work down the line. buy plugs first b/c they are cheap, then spend 40 or so on some wires (or use the oprotunity to buy some better ones)
Hope that helps, anyone, please add/correct.
Old Sep 24, 2004 | 05:15 PM
Ochdx's Avatar
Ochdx
wellp, just did what XS said, plugs are sparking, fuel is flowing, engine isnt starting
could ignition timing cause the engine not to start? i would imagine the engine should at least try to start, but the ignitior timing is off for sure, since i replaced the whole distributor
Old Sep 24, 2004 | 05:26 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
it should still start...just misfire.
*thinking more*
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Make sure your intake is clear.....if you are stock, for now, pull your filter, and leave the box open.
