Replaced distributor, car still wont start, HELP!
Old Sep 24, 2004 | 05:50 PM
  #31
Ochdx's Avatar
Ochdx
fuel pressure seems to be fine, disconnected the fuel line from the filter, put the ignition to on, and it sprayed like a bat out of hell
Old Sep 24, 2004 | 05:54 PM
  #32
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
i'd say try the same w/ the injectors then
worst case is sprayed fuel!
Old Sep 24, 2004 | 05:57 PM
  #33
Ochdx's Avatar
Ochdx
what do you mean sprayed fuel?
Old Sep 24, 2004 | 05:58 PM
  #34
Ochdx's Avatar
Ochdx
could it have anything to do with throttle body, tps, pcv valve?
Old Sep 24, 2004 | 06:00 PM
  #35
Ochdx's Avatar
Ochdx
could it be the distributor, its an aftermarket one... what if they shipped me one for civic ex engine, not dx - even though it produces spark, could that be the case?
Old Sep 24, 2004 | 06:06 PM
  #36
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
should still try to turn over though....
what i meant before, is if the injectors are "injecting" when they are unplugged, you will see fuel spray.
Old Sep 24, 2004 | 06:07 PM
  #37
Ochdx's Avatar
Ochdx
i see... not to be a prick, but just to make sure, the rotor defenately would not turn if the timing belt was broken?
Old Sep 24, 2004 | 06:16 PM
  #38
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
trying to visualize since im having a brain fart!
no, it shouldnt turn w/o the timing belt since the timing belt controls valve/ignition timing.
Old Sep 24, 2004 | 06:19 PM
  #39
Ochdx's Avatar
Ochdx
it sucks so much to have a dead car and tommorow is some jewish holiday, so my mechanic is closed, that means i wont be able to fix it until next saturday... that iis, if i can afford the repair
Old Sep 24, 2004 | 06:22 PM
  #40
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
here's a dumb one....check the engine ground wire. i remember hearing once that that connection can cause some really weird no start issues.
:Edit:
I wish i remembered exactly what that post was all about!! Searching now
